Old 11-10-2006, 06:53 PM   #1
1969k10stepside
Question Drive shaft question
My 71 swb k10 which had a 6 inch lift had a longer custom rear driveshaft.I am putting a new 4 inch all spring lift on it and I was wondering if I should use that driveshaft or a stock one.Do the swb have a 2 piece shaft w/ a carrier bearing like the longbeds or is a stock swb k10 rear driveshaft a one piece unit?
1969k10stepside is offline   Reply With Quote
Old 11-11-2006, 05:12 PM   #2
1969k10stepside
Re: Drive shaft question
Ttt
Old 11-11-2006, 07:04 PM   #3
qksilver
I have one complete and 2 rolling SWB trucks and they all have 1 piece rear drive shafts.
With the custom drive shaft you might bind because it is longer. Usually for stock to 4 inch lift the stock drive shaft is the deal
qksilver is offline   Reply With Quote
Old 11-11-2006, 07:48 PM   #4
1969k10stepside
This driveshaft extends in and out so I was wondering if it will work.I guess I need to take some measurements.
Old 11-11-2006, 09:27 PM   #5
qksilver
cycle the suspension to see if it binds
Old 11-11-2006, 10:32 PM   #6
1969k10stepside
Nothing is hooked up now,the t-case or axle isnt even together.I just want to know if I should rebuild this or look for a stock one to use.Here is a pic of this custom one extended and un-extended.Anyone ever seen one like this?
I think I should start looking for a stock drive shaft.
Attachment 224326
Attachment 224327
