Old 11-10-2006, 07:00 PM   #1
chadbork84k10
AXLE identification
Hey,
I believe is a gm 10- bolt rear on an 85 k10 but when replacing my axle seal the part listed at the auto dealer parts store was too small. On the side of the axle the number
TUM G291 and GM 34
I assume it is an aftermarket axle on the truck. It has a spool in it as well but that is besides the point. Any help w/ these numbers would be great.
Thanks Chad
chadbork84k10 is offline   Reply With Quote
Old 11-10-2006, 09:22 PM   #2
edman87
junk collector
Re: AXLE identification
easier with a pic or description of the shape and diff cover. Semifloating, full, c-clip? A 10 bolt would be stock, but you would be almost insane to spool one!
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 11-10-2006, 10:36 PM   #3
chadbork84k10
Ill try to get a pic tomorrow. Thought maybe the id numbers might mean something more. It's not stock because none of the stock seals work on it. I know it would be crazy to run a spool on a stock 10 bolt w/ 35's. Anyone else any idea's w/ those numbers. btw bought it this way planning to change rear end but changing seal in the mean time.
Thanks Chad
Old 11-11-2006, 09:27 AM   #4
magnethead
7000 #'s of american IRON
magnethead's Avatar
how many bolts on the diff cover? Might be a Dana 44 or corp 12 bolt??
magnethead is offline   Reply With Quote
Old 11-11-2006, 09:14 PM   #5
chadbork84k10
10 bolts on diff cover.
Old 11-11-2006, 09:38 PM   #6
magnethead
magnethead's Avatar
Surely it's not a hybrid axle..there'd be no use for a hybrid 10 bolt.
Picture will help
Old 11-11-2006, 09:50 PM   #7
chadbork84k10
It's the gm 10 bolt, but dont understand why none of the seals for the 10 bolt work? ANY suggestions? Its def a 10 bolt.
Thanks Chad
Old 11-11-2006, 09:57 PM   #8
magnethead
magnethead's Avatar
yup, it has tabs, so there's no question it's a 10 bolt centersection.
Thinking out loud here and highly unlikely- might it have 9 inch or dana 44 (even 30/35) outers?
did you try taking the old seals to the store and opening every box until you find a match?
Old 11-11-2006, 10:04 PM   #9
chadbork84k10
Did that and got one and it snaps in but they couldnt tell me what the seal was designed for. I hope it works? Just trying to get the right seal so i Wont have issues w/ it and or need further parts..
Thanks for the input, dunno if a pic of the input would help or not?
Thanks Chad
Old 11-12-2006, 04:55 AM   #10
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
You sure the parts place even has the right part number? You could try going to a different store and see what they give you.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
