Old 11-10-2006, 11:16 PM   #1
Gillnetter
Gillnetter's Avatar
Ac Or Non Ac
Aside from the AC vents in the dash of our '72 blazers, is there any difference on the engine room bulkheads of an AC or non-AC blazer?
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 11-11-2006, 01:20 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Ac Or Non Ac
There are a couple additional holes in the firewall with AC. I think the holes just aren't punched out in the non AC. The Battery tray is different too.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-11-2006, 03:06 AM   #3
Gillnetter
Gillnetter's Avatar
Re: Ac Or Non Ac
I was thinking of installing a non AC dash in my AC tub.Here is a picture of my tub .It is in pretty good shape just needs a little rocker and floorpan repair.
Old 11-11-2006, 06:05 AM   #4
vtblazer
vtblazer's Avatar
Re: Ac Or Non Ac
Why?
Don't like the AC dash? Or is it messed up?
It's a fair amount of work to swap out the dash but your at the perfect place with your tub to do it for sure.
vtblazer is offline   Reply With Quote
Old 11-11-2006, 12:01 PM   #5
bouncytruck
SKINNY TIRES RULE!
Re: Ac Or Non Ac
If you're not going to use AC, consider turning the side vents into hidden stereo tweeters.
bouncytruck 1972 K5
Old 11-11-2006, 01:27 PM   #6
Gillnetter
Gillnetter's Avatar
Re: Ac Or Non Ac
The dash is cut up pretty bad around the radio,ashtray and heater controls.Just thought it might be easier to swap dashes.
Old 11-11-2006, 04:56 PM   #7
vtblazer
vtblazer's Avatar
Re: Ac Or Non Ac
Post a pic of the dash, maybe a patch panel would work better for ya.
Changing out the entire dash unit is a P.I.T.A.
Old 11-11-2006, 07:28 PM   #8
kna4977
Re: Ac Or Non Ac
Edited by Moderator
kna4977 is offline   Reply With Quote
Old 11-11-2006, 08:23 PM   #9
Gillnetter
Gillnetter's Avatar
Re: Ac Or Non Ac
Thanks for the offer kna4977. As I don't have any of the AC components I'd rather put an unmolested non AC dash back in it. With the dash pad off I thought I could cut the vented ribs and make a dash swap. All I need is a non AC dash. I would like too find one locally or close by if possible.
Old 11-11-2006, 08:31 PM   #10
john
member #16
john's Avatar
Re: Ac Or Non Ac
Not too hard to change.
john is offline   Reply With Quote
Old 11-11-2006, 08:33 PM   #11
ClassicJimmy
FNG to resto/mod world!
ClassicJimmy's Avatar
Re: Ac Or Non Ac
Even if you don't want a/c, wouldn't the dash vents be worth it for winter heating? BTW - how much of a pita is it to swap the dash? I have a non-a/c & bought an a/c dash to put in. Probably won't do a/c at first, but I figure it looks & functions better than the non-a/c dash.
71 GMC Jimmy - under construction
75 GMC K25 Sierra Grande - under deconstruction
92 Chevy K2500 ECSB - sold
04 Nissan Titan ECSB Off Road - sold & missed
13 Ford F-150 Ecoboost (work truck) - sold
16 Ford F-150 Ecoboost (work truck)
ClassicJimmy is offline   Reply With Quote
Old 11-11-2006, 09:45 PM   #12
kna4977
Re: Ac Or Non Ac
No problem. If you change your mind let me know. I have some other A/C components + some non A/C components. Keep me posted on your needs.
Old 11-11-2006, 09:46 PM   #13
kna4977
Re: Ac Or Non Ac
It's easy to cut one out, don't know aboutputting one in. The A/C dash IMO definately looks and functions better.
Old 11-12-2006, 06:55 AM   #14
vtblazer
vtblazer's Avatar
Re: Ac Or Non Ac
To clarify for those wanting to run right out and change your dash, it is not that easy to do when removed as a complete unit!
Even when cutting between the holes that are beneath the dash pad. (easy part)
The hard part is removing the spot welds on the outside edges of the dash face welded to the upper pillar.
The flat tabs that are spot welded in FOUR places on each side have to be gotten to without doing damage to your thin dash sheet metal. (the one in the truck your saving)
Okay true, easy to do if you wanna rip it/bend it/wreck it to get it out but it's very tough to get at those tabs the way their located.
If possible a patch would be alot easier, even cutting out the center and replacing that section alone would save time/effort IMO.
Old 11-12-2006, 07:05 AM   #15
vtblazer
vtblazer's Avatar
Re: Ac Or Non Ac
If you go that route Gillnetter, you'll also need to have the rest of the A/C 'plumbing' parts, dash control, cables, vacuum pod and accessories to go along with it all.
Old 11-12-2006, 09:37 PM   #16
krue
Designated A-hole!
krue's Avatar
Re: Ac Or Non Ac
Lots of good info here, but the buying and selling (or offering to sell) belongs on the parts board, not here.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-13-2006, 12:25 PM   #17
ClassicJimmy
Re: Ac Or Non Ac
VT, are you saying that getting the dash out clean & reuseable is a pita, or putting one back in? Just checking because that is soon on the list. Thanks!
Old 11-13-2006, 06:06 PM   #18
vtblazer
vtblazer's Avatar
Re: Ac Or Non Ac
Leaving your existing dash intact AND installing the new face are both tough.
There is a flat metal tab spot welded to both the dash face and the inside of the upper door pillar.
In an effort to break loose the spot welds, you'll be tempted to put a small pry bar under the part of the dash that will remain in the truck, in doing so it's almost impossible not to dimple the metal from underneath.
The working space is pretty tight under there, if you go in knowing the possible issue's you should be fine.
Old 11-14-2006, 01:04 PM   #19
ClassicJimmy
Re: Ac Or Non Ac
Any chance for a pic?
BTW - Sorry for highjacking your thread Gillnetter! :hj:
