Old 11-11-2006, 01:33 AM   #1
ks147j111928
ASE Certified Spoon Operator
ks147j111928's Avatar
2wd axle into a 4wd truck
Hi everyone,
I just picked up another 67 C10 that has the factory 4.11 posi rear. At least that's what the build sheet says, we did jack up the axle and both tires spin the same way. My question is:
What else do I need to do besides spring perches? Should I alter the pinion angle? Are the 2wd wheel cylinders different from the 4wd? Am I doing anything right?
I know I'll have to change out the front gears to match the rears... air locker?
Let me know if anyone else has done a factory posi axle swap. Or anything like that.
Oh, this pic is the original front axle, D44 3.73 and closed knuckles. Keeper.
My six is bigger than your eight
67 K20 292 +.060" SM465 NP203 3.73s
86 4Runner, the daily on 31s
85 4Runner, the wheeler on 38s
92 x-cab truggy project for 2017... tons and 42s and V8 power
ks147j111928 is offline   Reply With Quote
Old 11-11-2006, 03:19 AM   #2
Americanrider
Re: 2wd axle into a 4wd truck
Set your pinion angle when you re-weld you pads. Normal for Chevy is 4 degrees, thats what on my 67 K20 with stock springs. Which rear is it, Eaton or Dana 60?
Americanrider is offline   Reply With Quote
