11-11-2006, 05:03 AM | #1 |
Another header thread...
These look like the same ones others on here are running, but I wanted to get an opinion before purchase. They list them as Camaro/Chevelle/Nova.
Those are the same wire looms I just bought, I only hope my engine looks this good some day. |
11-11-2006, 09:55 AM | #2 |
Re: Another header thread...
I have those looms from them on my truck very nice.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-11-2006, 11:16 AM | #3 | |||
Union Electrician
Those headers will not work. I just tried to put my motor in with them on and no way no how. The pass side fits with about a 1/16" clearance above the motor mount. The driver side is about a 1" from fitting, hits the motor mount. I really wanted to run these because of the length and the look, but it an't gonna happen
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
11-11-2006, 11:20 AM | #4 |
I bought the summit ceramic coated headers for somethin like 180 and they fit and look great
11-11-2006, 12:04 PM | #5 | |
I'm looking for a 3/4 length for under $200 if that's possible. |
11-11-2006, 02:14 PM | #6 | |||
Union Electrician
I too would like to find them IF they exist??? I really like the look of those headers camaro headers, and here is a pic with the pass side header on looks great, just wish the driver side would fit
11-11-2006, 02:21 PM | #7 |
I bought a set of chevelle headers that didn't fit too.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
11-11-2006, 02:43 PM | #8 |
Chevy Truck Addict
I also bought a set of the Heddman Chevelle headers and after a quick test fit realized they were not going to fit around the engine mounts. I did some research looking for a header with a 1-5/8" primary and found a set of Edelbrock headers that are built for a truck.
http://store.summitracing.com/partde...5&autoview=sku I did a quick test fit and the only problem I can see is the oxygen sensor plug interferes with the frame by about a 1/2" on the driver's side. It will be closed off anyway so I plan to "tweak" the frame a bit to make them fit. The passenger side fits like a glove. I am also real happy with the finish. I found the heddmans a little flat looking. The Edelbrock finish has much more of a shine to it. I will let you know once I get the cab off and truly fit the headers on the engine.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
11-11-2006, 02:45 PM | #9 | |||
Union Electrician
When will you be fitting the headers on your truck? I would like to get mine ordered asap to get the exhaust mocked up for my project
11-11-2006, 02:48 PM | #10 |
Chevy Truck Addict
I am planning to get the cab off today and that is the next thing on my schedule. Hopefully by the end of the weekend I will have some pictures for you.
11-11-2006, 03:18 PM | #11 | |||
Union Electrician
It states they have stock flages, so the donut gasket deal like rams horns on the ends?
11-11-2006, 08:38 PM | #12 |
My Chevelle/Malibu headers fit.
11-11-2006, 08:59 PM | #13 | |||
Union Electrician
where did your get yours shane? and what part # are they, and finally cost?
11-11-2006, 09:33 PM | #14 |
Chevy Truck Addict
Got my cab off today...
Continued to properly test fit my driver's side header... ground off the rivets and removed the linkage bracket from the frame which I don't need anymore. With the bracket out of the way, I was planning to notch out the frame to fit the oxygen sensor plug on the side of the header. After looking at it closer, I would have to remove about an inch out of the frame right above the shock mount. This is way too much for my liking. Well.. Back to the drawing board. Too bad, they are real nice looking headers. Shane, What part number are your headers? I tried a set of Hedman 68608's for a Chevelle and they interfered with the motor mounts. I may still try another set of Edelbrock's. There is another version that has a tube coming out the back of the header for the o2 sensor. It is in a fairly inconspicuous place so I should be able to cut and close this off without making too much of a mess of things. http://store.summitracing.com/partde...5&autoview=sku Thanks in advance for your help.
11-12-2006, 02:18 AM | #15 |
DynoMax from Jeg's ... purchased a few years ago so I am unsure of the part number. I searched Jeg's website but did not see them listed now.
If I can track down some paper work, I will post the part number. |
11-12-2006, 08:43 AM | #16 |
these headers fit well but they are full length and will not work with a big time dropped truck the fittment chart does not include our trucks but they fit let me know if you want pics my batteries are goin out again |
11-13-2006, 12:50 AM | #17 | |||
Union Electrician
I found these today and they say there are for a 88-95 trucks so they have the o2 bung, but from the pics it looks like the bung is facing up and should not interfere with the frame rails. It also looks like I will not have trouble with the motor mounts being in the way either, what do you guys think??
http://cgi.ebay.com/ebaymotors/CHEVY...QQcmdZViewItem
11-13-2006, 04:27 AM | #18 |
If you look at the pic at the top of this thread, you will see the same exact motor, with what looks to be the same exact headers, only difference i see is that the set you posted has an O2 bung.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 11-13-2006 at 04:29 AM. |
11-13-2006, 09:38 AM | #19 | |||
Union Electrician
brak, if you look again at the link I posted the front primary on both sides goes above the rest of the primarys in all the other one listed the front primary went under the rest of the primarys
11-13-2006, 10:14 AM | #20 |
The Dynomax fit because they have small 1 1/2" primary tubes. If you like the look of them Early Classics Ent sells some that are built to fit our trucks. Sanderson Makes them.
I am using "North West Auto Fab" motor mounts and the chevelle shorty headders.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
11-13-2006, 04:12 PM | #21 |
So would the 88-95 headers work as long as I plug the "bung"? I thought there was a head difference on the somewhat newer motors, so they wouldn't bolt up? The ad says it works with both types of plugs.
Those are from the same seller and I have had good dealings with them so far, so I would buy from them again for sure. |
11-13-2006, 05:17 PM | #22 | |||
Union Electrician
Jimmy, I looked at the pic again and the heads that are on the motor pictured are the old style, non-center bolt, so I would assume they would work for our application.They are closed for the holiday, but I will try again tomorrow to get the needed info and I will post what I find out.
11-13-2006, 05:29 PM | #23 |
jimmydean, just how low you sitting, that you want to run mid length headers? my hookers are up pretty tight to the crossmember. i can get you measurements if you like. pkj
11-13-2006, 05:39 PM | #24 | |
If possible, my setup will only be about 4' of pipe and muffler after the headers, then dump down like on a muscle car. I want to keep it above the frame and the ones on there now hang down quite a bit. |
11-13-2006, 07:06 PM | #25 |
Wrenchin & Sandin!!!
Randy Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG |
