Old 11-11-2006, 11:25 AM   #1
Sweet72
Sweet72's Avatar
Exclamation Carbon suppression plug wires
I just want to relate to you all the experience I went through with a set of Autozone's $36 spark plug wires. I have chased an intermittent miss on my Ford daily driver for some time... It all started with a simple tune-up new plugs cap and rotor and the Autozone wires, reset timing to factory spec. Man, she ran great after that for about 2 weeks and then she started to miss, would come and go, mostly when the weather was damp or raining and sometimes when it was bone dry. I chased electrical connectors and grounds, "misted" the wires and distributor with a spray bottle while running, I couldn't for the life of me seduce the gremlin to show his ugly head. I had replaced the module, distributor pickup, (2) cap and rotors sets, inspected and reinspected the plug wires many times for evidence of burning and/or arcing, they looked perfect. I was pulling out hair by the fist full by this time. Finally a new set of Accel Superstock spiral core wires did the trick.
Bottom line and lesson learned, no more carbon core radio suppression wires for me.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
