Old 11-11-2006, 12:09 PM   #1
boogie67
boogie67's Avatar
Lowering leaf springs??
So how do you lower truck with leaf springs in the back?I have a 72 chevy with leafs instead of coils.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 11-12-2006, 02:56 AM   #2
flatblack67c-10
flatblack67c-10's Avatar
Re: Lowering leaf springs??
brothers sells monoleafs for 67-72 trucks, pretty pricey, dont know much about them, i think they are like 4 or 5 inches of drop...drop shackles would be much cheaper, but im not sure if anyone makes them for these trucks, i know they make them for 73 and up trucks, a flip kit would also be a way to drop it, little more complicated, and more than just a bolt on though...
was 67 chevy swb fleet now muticolored 69 step, 350/350, 3.73 posi, converted to 5 lug, torq thrust II 17x8 front 17x9.5 rear, factory air cab, fuel cell. future plans: shaved wiper cowl, shave stake pockets, phantom grille, and silver paint...
68 camaro ss396 project
54 f*rd project truck
flatblack67c-10 is offline   Reply With Quote
Old 11-12-2006, 11:03 AM   #3
action
Active Member
action's Avatar
Not sure if axle is on bottom or top of spring but I think you can use an axle flip kit. which puts the axle on top of the spring. not sure of the drop but would say maybe 5".
Jack
action is offline   Reply With Quote
Old 11-12-2006, 11:44 AM   #4
see ten
WTB this ad
see ten's Avatar
Tim Christian is probably the man to ask. His GMC is on down there. I don't know his user ID off the top of my head. Tim is also a vendor on the board and an all around great guy!
see ten is offline   Reply With Quote
Old 11-12-2006, 12:52 PM   #5
beater69
Sinister Exaggerator
beater69's Avatar
air ride technologies makes a kit called "airoverleaf". you take out all but one leaf and then put a bag on top of the leaf and adjust your ride height. it is a few hundred $$. or you could track down some trailing arms and convert to coil rear. but the cheapest way is to pull one or two leafs out of your leaf pack and that will drop you an inch or two. that is what my dad and I did to his 3/4t, he had to buy new u bolts but those are cheap.
69 c10 Chevy Long Fleet 350/350 *under construction*
Poor man's disc brake upgrade with HydroBoost from '82 diesel
Blazer tank with "John Fabris" stake pocket filler (Genius!)
beater69 is offline   Reply With Quote
Old 11-13-2006, 12:54 AM   #6
russellmarling
russellmarling's Avatar
Early Classic Enterprises has them. I have them on my GMC and they lowered it more than I had planned on. They are multileafs like the factory ones.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress)
'09 CTS-V M6
'03 Sierra SWB Z71
'82 Yamaha Seca XJ650R Turbo!
'04 Yamaha FZ6
russellmarling is offline   Reply With Quote
Old 11-13-2006, 01:10 AM   #7
corn
A flip kit is @$100. Thats what I used on mine...
corn is offline   Reply With Quote
Old 11-13-2006, 04:34 PM   #8
Kuddy44
Can you guys post some pics with what ever lowering choices you made on your leaf-spring trucks? Also, with the leafsprings, will it change the back spacing required on wheels because of the leafs?
Kuddy44 is offline   Reply With Quote
Old 11-13-2006, 06:28 PM   #9
BarryB
BarryB's Avatar
Hey I had one that sat pretty low, probablly got a 5" drop from flipping the axle. This is probably the cheapest way tp go. look around for perches and U bolts. you most likely can make your own kit. And alot cheaper.
My .02 worth
BarryB is offline   Reply With Quote
Old 11-13-2006, 06:50 PM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
2" lowering shackles, 2-1/4" dearching of springs. Notched cross support on bed since bumps caused spings to hit. Stock back spacing with 275 / 45 / 20's
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 11-14-2006, 02:34 AM   #11
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
I'd also like to see some. Can anyone post before and after pics of an axle flip in the rear and cut coils and spindles in front?
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 11-14-2006, 02:35 AM   #12
JameslovesJammie
God Bless Mr. T
mocwon,
That is a gorgeous truck! What mirrors are those?
Old 11-16-2006, 12:19 PM   #13
mocwon
Keep On Truckin'
mocwon's Avatar
Thanks. The mirrors are off an early 90's Mazda Miata
Just Passin' Thru
