Old 11-11-2006, 05:42 PM   #1
myersjeremy
myersjeremy's Avatar
Washer Hose diagram
Anyone have a diagram for the windshield washer set-up for a 85 Silverado???
myersjeremy is offline   Reply With Quote
Old 11-13-2006, 08:16 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Washer Hose diagram
did you have a question about a set up? As far as the washer hoses go they run up the drivers side firewall across the top to either sprayers under the cowl or on the wipers. There are notches at the top of the firewall for the hose to go through. I actually had both cowl and wiper arm sprays on my 82, it covers the window nicely.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-13-2006, 08:21 PM   #3
ghetto_superman
ghetto_superman's Avatar
where is a good straight conversion to get somearm sprayer setup for a 67-72? i wanna run all that hose thru the cowl so you dont hafta see it in on the firewall..
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 11-13-2006, 08:54 PM   #4
Prerunner1982
The later years in the 73-87 (91) body style had them.. I ended up pulling mine off of a van because I couldnt find a truck with them.. however apparently the van wiperarms are a tab smaller then the truck arms so I had to zip tie them on.. you could run the tubes down the inside of the fender then under the cowl and then across the the arms if you wanted to hide all of the hose
Jon
Oklahoma Roll Call
