11-11-2006, 10:52 PM | #1 |
Weekend Warrior
A Few Slow Progress Pics - and a Dumb Question - Heater Box?
I got a little done on the K-10 today
Got the 250 that is going to go in it all cleaned up - ran out of orange paint so I painted the intake black. Gonna leave the exh. manifold rusty - cause mainfold paint will burn off it unless i sand balst it & i really done feel like doing that Got my seat back from the "seat guy" - turned out really nice actually. It's just a work truck and I don't need anything fancy - but I was very happy with the way it turned out - it's a greyish/bluish - more grey color ok so now for the stupid question. My truck originally had A/C - is doesn't work and that big heater box is under the hood taking up space & I took it out - cause a friendly little mouse made a house in it. will a regular "Non-A/C" Heater Box fit??? - I'm assuming that you have to change the under dash unit too as the heater core location is different. Thanks, Andy
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
11-11-2006, 11:14 PM | #2 |
Re: A Few Slow Progress Pics - and a Dumb Question - Heater Box?
Andy, for years I've been painting over rust on my manifolds with Eastwoods stainless steel coating and it has held up really well. I just did my M/C with it too, I even spilled brake fluid on it with no effect. Maybe you could look into this product as a quick fix, no sand blasting JMHO
I'll take pics if you want to see it!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-11-2006 at 11:15 PM. |
11-12-2006, 11:04 AM | #3 | |
Weekend Warrior
I just want to get the truck running and back on the road. I'll eventually put a V8 back in the truck or end up selling it Anybody know about the heater box?
11-12-2006, 11:33 AM | #4 |
man that is one BRIGHT ORANGE engine !! sorry cant help ya on the heater box since i dont have mine in the truck anymore (like i need it anyways,im in phoenix)
11-12-2006, 11:35 AM | #5 | |
Weekend Warrior
At least I'll be able to find all the leaks
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 11-12-2006 at 11:36 AM. |
11-12-2006, 11:37 AM | #6 |
The holes on the firewall are different for a/c and non-a/c. There's a place that makes an a/c delete panel, americangraffiti.biz.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 11-12-2006 at 11:40 AM. |
11-12-2006, 01:08 PM | #7 |
Old member
As far as the outside box, yes it will cover the dash holes but you need to fix them so the heater will perform as it should. The holes for mounting the BIG BLACK BOX are the same I'm pretty sure. You may have to redrill a mounting hole or two it's been some time since I did it. I did the oppisite of you and added air to mine. You can use all of your inside stuff to I think. All you want to do is change the outer peice. There again it's been awhile.
