Old 11-12-2006, 06:09 AM   #1
GREASEMONKEY72
GREASEMONKEY72's Avatar
vibration??????
ok when i get to around 40mph i feel a vibration and also when i step on the brakes at times to and i had thought it was the panhard bar causing it but i put in new bushings on both ends and it still vibrates so does anybody have any idea on what it could be and what i should look for/at??? any and all help/comments/opinions greatly appreciated thanks in advance
-steven
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 11-12-2006, 09:15 AM   #2
Boog
laying low
Boog's Avatar
Re: vibration??????
A few things come to mind like tire balance, warped drums, bent or loose wheels, carrier bearing or ujoints on the drive shaft, broken motor or tranny mounts are all possible sources for your vibration.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-12-2006, 09:49 AM   #3
jamon8
jamon8's Avatar
Re: vibration??????
check the busings in the trailering arms
jamon8 is offline   Reply With Quote
Old 11-12-2006, 11:07 AM   #4
GREASEMONKEY72
Re: vibration??????
thanks alot guys never wouldve thought of all that, so i guess when i get under there today ill look at more than just the carrier bearing, and i will let you guys know what happens
-steven
-steven
Alte Seele S.S.
