Old 11-12-2006, 10:55 AM   #1
HotRod73
HotRod73's Avatar
Light Question...
My interior lights do not come on. I know there is one under the dash and one on the headliner... both do not work and my bulbs dont appear to be burnt out... what could be wrong? i want them to work... is there a fuse for the lighting? could i just need all new parts?
HotRod73 is offline   Reply With Quote
Old 11-12-2006, 11:18 AM   #2
bodydropped69
bodydropped69's Avatar
Re: Light Question...
There should be a fuse for them. Also check the door pin switch. It sends a signal with door open to turn lights on.
bodydropped69 is offline   Reply With Quote
Old 11-12-2006, 11:28 AM   #3
HotRod73
HotRod73's Avatar
yeah they seem a bit worn but how do i test them? also what fuse is it? i dont see one thats blown...
Old 11-12-2006, 12:27 PM   #4
magnethead
7000 #'s of american IRON
magnethead's Avatar
turn the lights knob all the way left till it clicks, that's manual on. The fuse should be labeled right next to it in white writing.
magnethead is offline   Reply With Quote
Old 11-12-2006, 12:38 PM   #5
us111
also on mine there is an orange wire and a white wire that goes into a connector that plugs into fuse box..mine came off one time...
us111 is offline   Reply With Quote
Old 11-12-2006, 12:42 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
The orange wire is the ground circuit fot the lights. The door pin switches are nothing more than a sliding ground connector. Ift they get dirty or worn, then they don't work well. the headlight switch is also the other wasy to turn this light on. If the lights don't work with that switch then I would definitly look at the fuse.
piecesparts is offline   Reply With Quote
