Starting to put the cab back together. Had a video of taking it apart but was lost in the move. What order should you put thing back. Steering column, wiring, ac and heating, duct work, Everything under there. What order to save some time. Thanks for any help
Old member
Re: under dash install
I would start under the dash then wire it then add the steering it will just be in the way until you can drive it. Inless you have to move it around while you work on it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Better put the dash pad in 1st. Those speed nuts for the pad are hidden after other things are installed....then glove box, then heater assembly, brake and clutch pedal assembly, wiring harness, dash panel/gauges, then column. That was the order I put things back....
1997 GMC Sierra Ext 1965 Mustang |
