Old 11-12-2006, 03:55 PM   #1
phlegm
Still Green but learning
phlegm's Avatar
JB compound to stop a small header leak?
Leak is in the center of the collector, welding probably wouldnt get it, I have been told the JB stuff works good. I know the heat range only goes to 500 but my buddie told me he knew somone who patched a mani leak with it.....
any expierence out there?
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 11-12-2006, 04:05 PM   #2
ain't_done_yet
and won't ever be
ain't_done_yet's Avatar
Re: JB compound to stop a small header leak?
Ah yes...JB Weld. Their home is right here in Sulphur Springs. I know the owner of the company. Is good stuff. The stuff sets up STRONG!
'82 SWB 1/2T Silverado (project)
'96 SWB 1/2T Silverado, factory leather, Sony CD, Sirius Satellite
2006 Ram 3500 Megacab 4x4 SRW, AMSOIL/Injen CAI, AMSOIL By-Pass, Mag-Hytech cover, AMSOIL Lubriants throughout, and much more!!
CHANGE YOUR MIND...NOT YOUR OIL
ain't_done_yet is offline   Reply With Quote
Old 11-12-2006, 04:13 PM   #3
BarryB
BarryB's Avatar
Yeah it might work, but make sure it is clean then rough up the surface to get a good bond. Out of curiousity what exactlly is leaking the collector gasket or is there a hole in the collector?
BarryB is offline   Reply With Quote
Old 11-12-2006, 04:35 PM   #4
QKENUF4U
QKENUF4U's Avatar
being its down low and wont get nearly as hot as at the head it may work. i tried to use it on my toyota one time and it turned to water as soon as the exhuasut manifold got hot.
QKENUF4U is offline   Reply With Quote
Old 11-12-2006, 04:39 PM   #5
phlegm
phlegm's Avatar
where the 4 tubes combine, inside their, thats why a weld would be so tough. Its not the gasket (per the trusted exhaust guy)
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 11-12-2006, 06:22 PM   #6
mbgmike
We used it on a stock cast exhaust manifold and it lasted 3 or 4 months
mbgmike is offline   Reply With Quote
Old 11-12-2006, 06:39 PM   #7
CPNEJR
CPNEJR's Avatar
we tried it and many other things on the headers that were in our 1 ton but when down shifting the backpressure blew it out
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-12-2006, 07:36 PM   #8
Bob D
Rolled on Paint Club
Bob D's Avatar
I had a Headman header on a 1980 Toyota PU that lasted 12 years. It kept rusting out in the same place you mentioned and I just took it to the local garage and they welded it twice during it's life time.
Bob
They have to weld it from inside the collector.
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 11-12-2006, 10:06 PM   #9
Sweet72
Sweet72's Avatar
I tried JB Weld on my '72's stock exh. Y-Pipe and after two days of smelling burning epoxy, it finally said "I'm outta here" and fell to the blacktop.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-12-2006, 11:28 PM   #10
GMCMAX
Active Member
GMCMAX's Avatar
If you want to putty it, use muffler and tailpipe putty from NAPA, the hotter it gets, the harder it gets, had good luck on a 327 mani with it.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 11-12-2006, 11:48 PM   #11
casterbuster
Mejor Que Nada
casterbuster's Avatar
jb weld will not work, it does not expand and contract the same way the steel in the headers will, It will not last
The only thing that separates
"Dreams" from "Reality"
is TIME and MONEY!!!
casterbuster is offline   Reply With Quote
