Old 11-12-2006, 04:47 PM   #1
nvrforgotten52
nvrforgotten52's Avatar
2wd rear lift coils
i have been looking around for some coils for my work truck (1970 c10) and i want to raise the suspension an inch or two. i can find front lift coils but no rear coils? is there any company that makes those or any other way to raise the rear of this truck an inch or two. thanks
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 11-12-2006, 06:57 PM   #2
Ram-Man
Ram-Man's Avatar
Re: 2wd rear lift coils
I would think you could use 3/4 ton coils.
Ram-Man is offline   Reply With Quote
Old 11-12-2006, 07:59 PM   #3
watahyahknow
watahyahknow's Avatar
couldn't you just raise the coilperches by welding a 2 inch piece of square tubing between the perch and the frame itself , you can still use the stock springs then
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-13-2006, 06:53 PM   #4
KSCHEVYUP
KSCHEVYUP's Avatar
ttt-----Any other ideas?
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 11-13-2006, 06:58 PM   #5
CPNEJR
CPNEJR's Avatar
ram man 3/4 coils wont work because they are the same as a 1/2 w HD springs and HD springs or not the 1/2 tons are at the same height
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-13-2006, 09:30 PM   #6
Green Machine
Green Machine's Avatar
I used the 34-2820 variable rate springs on the back from LMC, (before i found this board) they raised it up about 2 inches at the bumper.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-14-2006, 04:56 PM   #7
nvrforgotten52
anyone else have any ideas?
