Old 11-12-2006, 06:49 PM   #1
Dirkstruck
1953 Chev Panel Truck
Hi Guys,
Wondering if 53 Chev panel truck has same rear bumper as a 47 to 53 1/2 ton truck? Thanks in advance for the help.
Dirkstruck is offline   Reply With Quote
Old 11-12-2006, 08:00 PM   #2
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 1953 Chev Panel Truck
I'm not sure about that, but I wanted to say welcome to the board!
CAL 58 GMC is offline   Reply With Quote
Old 11-12-2006, 08:56 PM   #3
entourageguy
Yellow truck club
entourageguy's Avatar
Hello to a fellow Canuck!!!!
Can't tell you the answer but wanted to say welcome.
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-12-2006, 10:54 PM   #4
qksilver
same here, not a clue but welcome to the board
qksilver is offline   Reply With Quote
Old 11-13-2006, 03:09 AM   #5
71/454
Turbo Guy
71/454's Avatar
Dirkstruck are you still interested in those bucket seats for the panel van?
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 11-14-2006, 01:42 AM   #6
Daniel U
Daniel U's Avatar
http://www.141.com/chevy/53panel/photos/rear.jpg
Looks like they are in this pic.... Hope it helps.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 11-14-2006, 01:55 AM   #7
Dirkstruck
I found one more bucket seat for the 53 panel truck I am doing a frame off resto. However it is missing the bottom cushion box spring. Other wise it is complete. I thought I could possible get away with using heavy foam with a plywood bottom. However I would be willing to hear what you have. Since I am trying to make as original as possible. I am also looking for front fenders that are better shape than the ones I have now. These will cost a bit to repair. I hear that after market ones will be availabe soon but they don't fit well. Thanks for any help.
Old 11-14-2006, 12:29 PM   #8
orgalmeister
I read somewhere that the panel truck used the same bumper front and rear. might be worth checking into.
orgalmeister is offline   Reply With Quote
Old 11-15-2006, 04:53 PM   #9
71/454
Turbo Guy
71/454's Avatar
Ok I will try to get a pic today or the next. Ther is not much left of the seats for material though just springs and the base. I need some parts too so maybe we can trade. Sending you a pm
12 bolt diff
Old 12-02-2006, 07:05 PM   #10
BigSix302
BigSix302's Avatar
Welp, Panels and Suburbans are the same. I have a Burb and I used the same bumper on the rear that I put on the front. You do have to have the correct rear bumper brackets. These are different than the pick up rear brackets and are a little harder to come by. I think you can still find them. You might check with "Mother Trucker" out in Arizona on these brackets, as he has a bunch of parts trucks out there. Or maybe "Iron Chief" since you are up in Canada.
AD's Rule!! 53 GMC Suburban--48 GMC 1/2 Ton project--49 Chevy Pick-up--52 Chevy Pick-up (my driver)
BigSix302 is offline   Reply With Quote
