11-12-2006, 08:48 PM | #1 |
rear window
I have a sliding rear window on my 70 that is all messed up and I plan to replace with a solid piece of glass.
Are the window seals the type that can be installed by putting a cord in the groove and pulling it out over the metal lip or do they have to be glued in? |
11-12-2006, 08:50 PM | #2 |
Re: rear window
the do not have to be glued in they are pressure fit
(Only) Member of the CPNE Fan Club Aint that the truth 67 C-10 350 with 3-speed tranny and 308 gears swb step 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
11-12-2006, 08:51 PM | #3 |
Re: rear window
make sure they are supple (warm) and some kind of lube and you will be fine
11-12-2006, 09:11 PM | #4 |
Re: rear window
Thanks for the quick replies. I've replaced these type of seals in vw's. I usually let the seals sit on the driveway for an hour to warm up before installing, then use 12 ga wire and soapy water to install
11-12-2006, 09:12 PM | #5 |
Re: rear window
since its the rear window definitely make sure you have a buddy to help hold it in place and apply pressure
