Old 11-13-2006, 03:17 PM   #1
pat
pat's Avatar
Crappy video of my motor
I took a video of my truck running the other day, still am not at the point of driving it yet. It needs to have the timing set really bad. Sound isnt that great and its dies when it runs out of gas. But it sounds pretty good in person through the open headers
http://smg.photobucket.com/albums/v6...gAnch=imgAnch1
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 11-13-2006, 03:35 PM   #2
71chevylowrider
71chevylowrider's Avatar
Re: Crappy video of my motor
sounds pretty darn healty, I like the open headers, sounds like a dragster. I'm glad that camera strap didn't swing down & get caught in a belt/fan
71chevylowrider is offline   Reply With Quote
Old 11-13-2006, 05:47 PM   #3
pat
pat's Avatar
Thanks. Yeah, that camera has since been run over and crushed, I have pretty bad luck with digital cameras.
Im not sure how much of the sound is the timing being off or my cam...
http://store.summitracing.com/partde...0&autoview=sku
Old 11-13-2006, 07:01 PM   #4
Big Block
Big Block
Big Block's Avatar
Can you say big cam shaft!
Big Block is offline   Reply With Quote
Old 11-13-2006, 08:28 PM   #5
pat
pat's Avatar
Are u saying that b/c of just the sound or did u check out the camshaft?
B/c I dont really know much about cams and Im curious as to how it will sound when it gets timed and some pipes put on it.
Old 11-13-2006, 08:37 PM   #6
arkracing
Weekend Warrior
that's a good all around street cam. Open Headers usually make a Cam sound bigger than it really is.
quick question though - is that the first time you started the motor??
i.e.(did you "break-in" the cam?)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-13-2006, 08:55 PM   #7
Green Machine
Green Machine's Avatar
My thoughts too, hard to hear any problems in a new motor with open headers, and if that is a new cam ???
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-13-2006, 09:01 PM   #8
pat
pat's Avatar
It is a new cam. I didnt build this engine, I had a shop do it b/c I dont have near the experience/knowledge yet to do so. They also ran it on the dyno so I assume they did "break-in" the cam.
Thanks!
Old 11-13-2006, 09:08 PM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Interesting...I got the SUM-K1102 with the same lift and duration because it was a mild cam! I noticed that your advertised duration is higher however. Sounds great but I am curious about that 1500+ rpm, 20 minute, break-in too? BTW...beautiful engine!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-13-2006, 09:11 PM   #10
msgross
msgross's Avatar
[QUOTE=pat;1880946]I took a video of my truck running the other day, still am not at the point of driving it yet. It needs to have the timing set really bad. Sound isnt that great and its dies when it runs out of gas. But it sounds pretty good in person through the open headers
QUOTE]
Mine always does that too,
sounds mean though...I have no exhaust yet and fired mine up like that.......neighbors love me!
msgross is offline   Reply With Quote
Old 11-13-2006, 10:25 PM   #11
shane72_383
shane72_383's Avatar
Sounds good, theres nothin better than open headers. My favorite part is the backfire through the air cleaner....
shane72_383 is offline   Reply With Quote
Old 11-13-2006, 11:53 PM   #12
QKENUF4U
QKENUF4U's Avatar
sounds NASTY !! if they did a dyno run for ya then that cam is broke in. very nice looking engine also.
QKENUF4U is offline   Reply With Quote
Old 11-14-2006, 03:43 AM   #13
pat
pat's Avatar
Thanks guys. Wow, I never noticed that backfire until now...
Old 11-14-2006, 09:23 AM   #14
msgross
msgross's Avatar
when i put my Holley on it backfired out the top, thankfully I didn't have a lceaner on yet since it looked like a dragon throwing fire! Didn't blow the carb but scared the poop outta me....ran fine after dialing in the timing...
Old 11-14-2006, 12:37 PM   #15
shane72_383
Ya, backfiring through the carb gets interesting. When i first put my double pumper on my 383 i went to start it and it fired right up. As i sat in the truck and listened to it, the fuel line wasn't tight and was puking gas all over the intake. I finally went up and checked it out, seeing this i shut it off immediately. I went to start it again and for some reason it backfired through the carb and caught all the spilt gas in the intake on fire. Needless to say it scared the poo out of me.
Old 11-14-2006, 04:20 PM   #16
beater69
Sinister Exaggerator
beater69's Avatar
sounds good, the flame through the air cleaner at the last is pretty cool too
69 c10 Chevy Long Fleet 350/350 *under construction*
Poor man's disc brake upgrade with HydroBoost from '82 diesel
Blazer tank with "John Fabris" stake pocket filler (Genius!)
beater69 is offline   Reply With Quote
