![]() Join Date: Mar 2003
On the positive battery cable , does the little wire hook up to the little black block on the passenger inside fender ,with the little bolt coming out of the middle? and on the negative battery cable does the little wire go to the inside of the fender to ground? Thanks guys my truck is getting there. I'll have some pics pretty soon. Thank you .Dave
![]() Join Date: Sep 2005
Re: Both battery cables (littlewire ?)
yes on the positive you have a wire goign to the black block on the fender it feeds the rest of the truck and as to the groun idk mines ground to the block the big wire and theres no little wire
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
mine grounds to the block and then there is a ground from each valve cover to the frame.
(402BB)my negative cable grounds to the water pump , but there is also a little wire that comes out on the negative cable right where the negative attaches to the battery.
Running on empty
The little wire on the negative side wire is not needed
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
its all about the +6 inches
Actually, IIRC there is no ground strap to the rad support... that ground pigtail is quite important.. the headlights as a pair are the most demanding items on the truck. Without a proper ground, they'll glow a dim embarasing orange instead of white.
ground nearest to the starter off the batt.
new aftermarket battery cables have extra (small) wires coming out near the post.
It is the newer type cable. so where does the little wire go? Thank you.Dave
core support
![]() Join Date: Jul 2004
Extra grounds never hurt, I aways put a ring terminal, soldered if you want on the extra ground from the Neg terminal and run it to the top bolt on the side of the battery box.
On the Pos side, on 67-70, the wire that connects to the block on the fender, you should use a 16 ga fusible link, soldered and heat shrinked. 71-72 IIRC put the fusible link in the main red wire going across, so you can use regular wire there on those years. The large end of the ground wire usually goes to the water pump, or it may look bettter going to the head, scrape paint fron the head, use a star washer under the cable for best contact.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 11-13-2006 at 08:32 PM. |
I believe mine went to the inside of the fender.Does anyone else have it there? My truck is a 72' BB GMC. I'm Trying to keep it in the origional loacation. Thank you
#13 |
Can some of you please check where your little ground wires are located on your trucks and let me know? Thank you. Dave
