11-13-2006, 06:39 PM | #1 |
Tires
Whats the widest tires that can fit on a 72 Chevy Fleetside Longbed and not stick out the sides and still look great?
11-13-2006, 06:44 PM | #2 |
Re: Tires
It depends on the offset of your wheels... Ive seen 33x12.50's on a stock 68 3/4 ton and I thought it looked good. they werent sticking out.
11-13-2006, 07:10 PM | #3 |
Re: Tires
i have 255/70r15 on mine mine rims are 15X10s
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
11-13-2006, 11:41 PM | #4 |
67-72 Addict!
Re: Tires
Yep, all depends on offset.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-13-2006, 11:55 PM | #5 |
Re: Tires
I've seen 275/60 15's on rear of some trucks and about a 255/60 15 or 255/70 15 on the front.
11-14-2006, 02:03 AM | #6 |
Re: Tires
C'mon........Let's think just the right offset. I know you can fit larger than a 275 series tire on these things. I've wondered this as well since I'm thinking I can fit an 18x10 wheel with a 295/45/18 on it and have it fit nicely in the wheel well with about a 7" drop.
What's the biggest wheel tire combo somebody's gotten away with (lowered 2wd fleet)? Widest rim???.....(with the right offset)!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
11-14-2006, 02:15 AM | #7 |
71 rustless in texas
Re: Tires
I've had 295/60/15 BFG's on mine for a couple of years. There on 15 X 10 truck rallies. No scrubbing or scraping. the trucks got about a 2/4 drop (from old springs).
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE Last edited by kbs71; 11-14-2006 at 02:16 AM. |
11-14-2006, 02:30 AM | #8 |
Re: Tires
Come to think of it, I have heard of people putting 295's on them and it sounds like its working for Jim and kbs. Do either of you guys have pictures of your truck that you could post on here so we could see how they look with the wide tires on them?
11-14-2006, 03:04 PM | #9 |
Re: Tires
Radman has 255/70/15's in front and 285/70/15 in the rear of his truck. I don't have any pics of it, but if you send a PM, he might send you some.
11-14-2006, 04:44 PM | #10 |
Re: Tires
Way back when I first got mine, it had 295/50/15's on a 10 inch wide rim (backs) that did fit with some occasional rubbing when I had a load in the back, but that was mainly because the rim had a little too much neg. offset. Looked to me that there was plenty of room to tuck them in a little further. I don't have the 295/45/18's yet.....that's just my plan....at least for today! Seems it changes daily!!!
I ended up putting 275/60/15's on cuz they just filled up the wheel well better and where a little more inside the fender. The pic is with the 275's.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread Last edited by SactoJim; 10-04-2007 at 05:19 PM. |
11-14-2006, 05:39 PM | #11 |
Active Member
Re: Tires
I was running 255/40/20 on my front and 275/40/20 on the back with 20x9.5 rims with 5" backspacing and tuck no problem with it dropped.
11-14-2006, 08:51 PM | #12 |
Re: Tires
This is my truck..285 35's on 22x9.5's with 6 in backspacing..Fit good up front, no rubbing.. Tuck too much in the rear so im gona space them out. Im pretty sure im gonna go with 285 45's though before it gets on the road if theyll fit. Last edited by bs25j; 11-14-2006 at 08:53 PM. |
11-14-2006, 08:58 PM | #13 |
Re: Tires
if you want to cut the bed floor back to the frame rails you can get a
mt 31-16.50-15 under it with the right offset wheel. if i remember correctly a 5 or 5.5 offset will get those under it but i don't remember 100% what the offset needs to be
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 11-15-2006 at 12:22 AM. |
11-15-2006, 03:11 PM | #14 |
Re: Tires
Here is Radman's truck. Hope he doesn't mind me posting pics of his truck.
11-16-2006, 05:43 PM | #15 |
Re: Tires
What kind of backspacing would you guys recommend with 275/60 15's on rally wheels?
11-16-2006, 06:27 PM | #16 |
Re: Tires
I know if you go 305/50R-15's your not gonna tuck that meat!
