wheels and rear end questions.
hey I was wondering if any of you could help me with some questions, first I was wondering why newer rims dont fit on the old trucks, i want to put 20's on but when i emailed american racing if they fit they said they wouldent, now i belive it has something to do with the wheel bearing and such? is there any way to fit that to fit newer rims on? I plan on putting on drop spindles and pulling the disc brakes out of a 72 truck. also what trucks had a stock posi rear end i could put into my truck or what do i look for when at the wreckers for rear ends pref. 373, my 411's are abit tough on the tires and gas :P
Re: wheels and rear end questions.
I have 20's on the back, also have 3.73 and posi... my truck is a 70 and the rearend was stock... look for a 12 bolt pattern for starters... at least thats what mine has. Heres a before pic....
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd Last edited by redneckdds; 11-14-2006 at 12:11 AM. |
thanks, now to put rims on the front what do i have to do since, ive been told they dont just bolt up onto it, thanks for the help
stock style rims generally wont fit for 2 reasons. 1- backspacing.. on the back for example the backspacing is so great that the tire hits the inner tub of the bed. and 2- the axle hub is a bigger diameter on the older trucks than it is on the newer trucks. to make the rim fit, youd have to mill out the hub hole in the newer rim. not really worth it IMO.
-1947 3100 -1968 C10 -1970 K20 |
#5 | |
Hope this helps. J
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
Active Member
![]() Join Date: Oct 2006
No problem on mine I run 20's with 5" backspacing all around and they fit fine. I have a 72 with the 12 bolt rearend.
I'm running a 20x10 Torq Thrust II out back (centered- 5" in, 5" out) with the factory 12 bolt and no problems.
Low and Slow (for now!) |
I was looking at some 5 lug wheels off a 88-98 c1500. Will they fit or will I have to take some off?
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
#9 | |
Yup, I'm comp-useless
I'm not sure if the steel rims will work, but the aluminum wheels, as mentioned, didn't. |
thanks for the help, just sounds like ill have to make some custom modifications, i wish i could just get some torq thrusters, but im running 6 bolts. ahah
They do make a 6 lug Torq-Thrust, but it is 6 spoke.
yeah, not as easy to find a used set, they used to make a nice set VI i belive but they stoped making them and went to a similar look but not as nice. iv been looking at the american racing rts wheels they seem to be some what affordable.
#13 |
Outlandish Trends - FL
OK, I went through the same situation and here is what you need to do to run the newer style wheels if you want it done "right". The problem is the axle flange on the rear is a larger diameter than the new style wheels will allow. I pulled my axles out and took them to a machine shop and had them "turned" on a lathe to the proper hub bore diameter of my new wheels. This fixes the problem forever, and should you decide to ever switch wheels down the road, you won't have to go through the process again. It's not hard to pull the axles, and it only cost me $50 if I recall to have them turned. You could bore out the hub of the wheels, but why? First of all, if you ever want to rotate your wheels, you'll have to do it to ALL 4. That costs more. What if you want new wheels down the road? You gotta do it again. Makes sense to do the axles, not the wheels.
-Bret 67 short-fleet sold! |
#14 |
installing 20's on c-10 is not a problem. you just have to get a wheel with the correct backspacing. i have 20x8.5 Equus brand wheels on my 72. i had previously had those wheels mounted on my 99' yukun before i traded it. they fitted with no problems or mods. they ride and handle just like the factory wheels did.
#15 | |
#16 |
Freeeeee Mason...
I've also run into this problem but I'm fairly sure MOST Boss wheels will fit. I was trying to fit a set of 20" Driv Reality and they wouldn't fit the back.
