Old 11-13-2006, 08:35 PM   #1
billsbowtie
billsbowtie's Avatar
good driver shape cab f/s
here is a nice driver shape cab restore has been started .the cab corners have been replaced it needs driver outer rocker. floor and inner rockers and floor suports look good. floors have had miner work done on top inside cab it was not bad all the way threw. bare cab with out doors, brake booster,auto colum, floor shifter,$500.00 . if you need any of the other parts seen on cab in pic. i will make you a price with the parts you need. cab does have good ky paper work with it and radio has been cut but i will throw in a patch with it. respond here first if interested in it.[SOLD]
billsbowtie is offline   Reply With Quote
Old 11-13-2006, 08:37 PM   #2
billsbowtie
Re: good driver shape cab f/s
if you want the 72 lwb frame leaf spring 5 lug with cab add $100.00.
Old 11-13-2006, 08:38 PM   #3
billsbowtie
grille and rad.suport add $50.00.
Old 11-13-2006, 08:38 PM   #4
billsbowtie
Old 11-13-2006, 08:39 PM   #5
billsbowtie
cab around windshield was sanded and primmered.
Old 11-13-2006, 08:39 PM   #6
billsbowtie
Old 11-13-2006, 08:40 PM   #7
billsbowtie
Old 11-13-2006, 08:40 PM   #8
billsbowtie
Old 11-13-2006, 08:40 PM   #9
billsbowtie
Old 11-13-2006, 08:40 PM   #10
billsbowtie
Old 11-13-2006, 08:41 PM   #11
billsbowtie
Old 11-13-2006, 08:41 PM   #12
billsbowtie
Old 11-13-2006, 08:41 PM   #13
billsbowtie
Old 11-13-2006, 08:43 PM   #14
billsbowtie
Old 11-13-2006, 08:43 PM   #15
billsbowtie
Old 11-13-2006, 08:44 PM   #16
billsbowtie
Old 11-13-2006, 08:44 PM   #17
billsbowtie
Old 11-13-2006, 08:45 PM   #18
billsbowtie
Old 11-13-2006, 08:45 PM   #19
billsbowtie
Old 11-13-2006, 08:45 PM   #20
billsbowtie
Old 11-13-2006, 08:46 PM   #21
billsbowtie
Old 11-13-2006, 08:47 PM   #22
billsbowtie
Old 11-13-2006, 09:39 PM   #23
qksilver
Bill, is that frame straight from the cab back. I can't tell by the pix. No kick out? like what would mount a coil spring on a trailing arm rear suspension.
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 11-14-2006, 12:07 PM   #24
billsbowtie
steve frame is nice shape.
Old 11-14-2006, 03:02 PM   #25
sameyrasmea72
sameyrasmea72's Avatar
Thanks,
Steve
Qksilver, The frame on my 72 leaf does have the "kick out" just like the coil spring frame even though nothing mounts there.. In other words it's not straight like the 4x4 frame.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
