11-13-2006, 10:26 PM | #1 |
locking point in column??
Any one have a column with locking shift points in their 71'??
--thanks --den |
11-13-2006, 10:40 PM | #2 |
Re: locking point in column??
oh common guys, its a simple yes or no answer.
11-13-2006, 11:21 PM | #3 |
its all about the +6 inches
What do you mean by locking shift points?
11-13-2006, 11:45 PM | #4 |
11-13-2006, 11:47 PM | #5 |
Wrenchin & Sandin!!!
Randy Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG Last edited by Draggn66; 11-14-2006 at 11:38 AM. |
11-13-2006, 11:57 PM | #6 |
I think mine might but it is only when I shift out of park. It is hard to tell because it is really subtle and the shifter is original.
11-13-2006, 11:59 PM | #7 |
thanks guys, any one else???
11-14-2006, 12:40 AM | #8 |
they all were originally
11-14-2006, 01:34 AM | #9 |
hummmm... mine isant. its, bump the shifter down and it will fall down. only poins holding it are in the tranny...
11-14-2006, 11:27 AM | #10 |
Spanked once
Yes it does, It took awhile but mine is like new and it is hard to get used to after all the slop it had. Now PRNDL2L1 means something on the column.
11-14-2006, 11:17 PM | #11 |
...... so mine may be frozen??
11-14-2006, 11:45 PM | #12 |
it's doubtfull it's frozen as it's not a very complicated setup in a non tilt column.
you may just need to adjust the tention on it. at the the base of the column there are 3 1/2 bolts that hold what looks like a spring clamp on. loosen the 3 bolts but don't remove them. by turning the black spring clamp the 3 bolts go through you should beable to adjust the tention on the shifter. you may be able to do this by hand but more likely you'll need a pair of channel locks. retighten the 3 bolts. ondrew |
11-15-2006, 12:01 AM | #13 |
pics???... please, im lost.
11-15-2006, 12:24 AM | #14 |
Spanked once
I will look tomorrow to see what the previous post is saying about the 3 bolts, it may be easier than what I did or maybe simpler.
11-15-2006, 12:39 AM | #15 |
cool, thanks everyone!!!!
