Old 11-13-2006, 10:48 PM   #1
68jimmy
68jimmy's Avatar
Tips on centering rear end?
Any good tips on centering the rear diff? I have installed a set of 3" drop springs and will probably get a set of 2" blocks to finish it off. With that much drop I'll need to get an adjustable panhard bar as well. And I'll need to get it all lined up correctly so as not to tear up my carrier bearing... Which may be part of my issue now with a new vibration. Also how much of a pinon shim will I need with a total of 5" of drop? Any help appreciated!
donovan
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 11-13-2006, 11:05 PM   #2
Psycho71
Psycho71's Avatar
Re: Tips on centering rear end?
On centering the rear end; With the weight on the tires, measure from the frame rail to the brake backing plate, in the same place on each side. Then use a ratchet strap attached to the rear end & frame to pull it over until distance on each side is equal. Adjust panhard bar, and install.
I did plagerize this from another thread. But I did mine this way and it worked fine. So credit goes to the original author, whoever they are.
I dunno about the pinion angle.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 11-14-2006, 09:50 AM   #3
68jimmy
68jimmy's Avatar
Thanks for the info...
Old 11-14-2006, 12:05 PM   #4
byrd
Union Electrician
byrd's Avatar
I just did mine the same way,3" springs and 2" blocks, no pinion angle isuses with a 5" drop the way we did it(or at all with 5", 6" and up will need some help)
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-14-2006, 12:13 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
I measured mine the same way but just pulled the body over and hooked in the adjustable sway bar once I had it set correctly.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
