Out of the carpool lane.
Difficult time trying to find a clutch disc for a T-5 trans
I'm in the middle of attaching a T-5 transmission to a stock 250 flywheel. I believe I have a 1988(unsure of exact year) S-10 T-5, with a 14 tooth(yes, 14 tooth) input shaft. What I'm looking for is a 14 tooth disc that's right at 10" or slightly under to fit my existing clutch which has alot of miles left on it. I understand that there might be a 9-1/8" disc out there, but I'm afraid that might be too small for a 1/2T truck.
Basically, I'm trying to avoid buying a new flywheel to match up to the T-5 clutch packages because right now the clutches I've looked at- the outer bolt circle diameter is too small to mount it to my stock flywheel.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Re: Difficult time trying to find a clutch disc for a T-5 trans
Check a early astro van with a 5 speed . I believe it is a 9 3/4
![]() Join Date: Jul 2004
Found this NAPA number for a 9 11/16 RCF4201 you can check it out
This was for a 1984 Camaro with a 2.8 V6 http://www.napaonline.com/masterpage...h+Disc+-+Remfd
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 11-13-2006 at 11:54 PM. |
the camaro and the astro should be the same
You also might check with www.specclutch.com. They are a little pricey, but really good stuff.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
Thanks guys. I ended up getting the original disc, but now I'm having other issues trying to mount this thing up.
