New Member
![]() Join Date: Nov 2006
Lowering front with new springs problem
Here’s the problem: I planned to drop my truck 2” in the front and 4” in the rear using new springs (I’ve got drum brakes). I ordered the springs from CPP. The 4” drop in the rear was just what I wanted, but the front was another story.
Before I installed them, I laid the 2” drop front springs next to the old springs and they were about 1˝” shorter, which seemed about right. But after I put them on, I got no change in height. Since then, I’ve had the springs back off 3 times to see if there was something wrong with the way I installed them but haven’t found anything. Has anybody had a problem like this? Three pictures are attached - before, rear only lowered, and both front and rear. Thanks! |
Re: Lowering front with new springs problem
Were the front springs the originals? If so, I bet they were weak and sagged.
#3 | |
![]() Also, you have to consider that 67-72 1/2 ton C10s typically came from the factory with a 2inch difference in height between the front and rear. Now that you have new springs all around, the truck should be sitting even...as it looks like in the pics. Hope this helps... J
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
67-72 Addict!
redhot67- Nice truck!. I agree with the others about the old sagging springs. These new springs will probably settle down a little with time.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
New Member
I can't say for sure, but they may be. However, from looking at the truck, they seem to sit pretty high (both before and after). I'm thinking I'll drive it for a while, and if they don't drop any, try cutting a coil off the old springs. I'm not looking for a big drop, just enough to have a slight rake.
#6 | |
Also, when installing, be sure that that end of the bottom coil is situated toward the outermost side of the truck...away from the motor. Then drive it a while and go over some bumps to get it to settle in properly. I had to do that with my truck, my 71 Nova, and my 67 El Camino.
![]() Join Date: May 2005
I think you should get a fairly "even" stance with a 2/4 drop. Your's however is obviously not even.
Is it possible that CPP sent you a set of "big-block" front springs? Those would be a bit stiffer than small block springs to handle the extra weight. Just a thought. Pete |
#8 | |
67-72 Addict!
My truck has three quarters of an inch rake.
#9 | |
New Member
Redhot67, that's some kind of customer service..maybe cutting the springs would be your best option after all.
I checked Early Classic's web site, and they do sell two different springs for small and big block trucks. Nice truck by the way..anymore pics? Pete |
![]() Join Date: Feb 2004
i was told that all lowering springs had to be broke in that over time they settel down to there advertized hight. I did not buy my front springs though they are 3in drop springs off of a 2002 ford f150 they dropped my truck about 2inches and then setteled down another inch with the bb who would hav thought....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 11-14-2006 at 12:44 PM. |
![]() Join Date: Aug 2003
Just from experience, use Early Classic next time.
#13 | |
New Member
Pete -More photos when I get them off the camera - maybe tomorrow. uncle - Thanks for the tip. Wish I had gone there in the first place. Live and learn. |
#14 |
"Trucks with Class"
![]() Join Date: Jul 2000
...and of course NO company is going to take springs back after they have been installed or scuffed up. They can't sell them again when used.
We do the front first and then make the rear match it. We cover the rear springs with towels to protect them for the mock up fit, so they don't get any marks on them...and don't roll them around on the concrete floor! When they are spotless and in the clean original boxes, we can take them back and make changes/adjustments. Were your original springs light duty or six cylinder? |
#15 | |
New Member
#16 |
I bought a set of 1" springs from CPP a few years ago. Instead of lowering it an inch, i think it raised it an inch. They do have thicker coils so they will have a more accurate drop with a BB. I wasn't very satisfied with CPP's quality and customer service either. I wanted to buy from ECE at the time, but they're catalogs were backordered and I neede springs soon, and didn't have internet access either.
I kept the 1" springs I had and used ECE drop spindles and 4" rear drop springs for my truck now that I'm rebuilding it. I'm hoping for a 3/4 drop with a little bit of rake. My sig has pics of my truck with CPP's 1" front and 2" rear drop springs.
