Oilfield Trash
Feeling Bad Vibrations
My 72 SWB has a vibrations problem at 65mph and up the faster i go the worse it gets, feels like its comin from the front end. I had the wheels balanced, didn't change, should i look into an alignment? Mabye a driveshaft balance, even though it shouldn't because its a one piece, unless its bent or somethin?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Designated A-hole!
Re: Feeling Bad Vibrations
Check your tires carefully for knots or bumps or other irregularities.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Oilfield Trash
it was doing it before with the old tires too
alignments are good as are non worn suspension pieces
motor mounts tranny mount u joints cracked flexplate or loose torque converter can all be the cause of vibrations
Could it be wheel bearings?
Just went through the same thing and after a new driveshaft with no effect I decided to change out the tranny. (It really needed the 700r4 anyways). Got rid of the vibration but I really think the original problem was due to a bad rear tranny mount. Wasn't much left of it when I took out the TH400. Check the simple stuff first..!!!
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
check the mounts definatly but if they are good check the rotors for warpage and if its 4wd check the hubs see if they arent sticking when they dont need to be.
