Old 11-15-2006, 01:13 AM   #1
Slammed '87
Slammed '87's Avatar
Air Tank Size?
Just wondering if someone knows how many gallons of air can one of these tanks hold. i am getting one but don't know exactly. If you run it at 200ish psi is that quite3 a bit of reserve to play with? I only have a 5g now and its not enough, even at 200. thanks
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 11-15-2006, 06:04 AM   #2
69face
69face's Avatar
Re: Air Tank Size?
approx. every 6 square inches is 1 gallon so measure daimeter and length and multiply, then divide by 36 to get approx gallonage. those are originally built to handle large amounts of pressure, so that shouldnt be much of a concern. if the wall thickness is anywhere close to 3/16 it'll handle anything you plan to use it for suspension wise.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 11-15-2006, 06:21 AM   #3
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: Air Tank Size?
for me its about 50 times give or take up and down.. Are you going to be switch happy ?? 200 psi is good.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 11-15-2006, 01:52 PM   #4
pharcyde05
pharcyde05's Avatar
Re: Air Tank Size?
I use a large cyl to fill my tanks i have 2 9 gal tanks and i have to fill the larg cyl once a month
pharcyde05 is offline   Reply With Quote
Old 11-15-2006, 04:14 PM   #5
XXL
Seņor Member
XXL's Avatar
Re: Air Tank Size?
There's a punch line in there somewhere...
:happy:
XXL is offline   Reply With Quote
Old 11-16-2006, 05:11 PM   #6
camaro__thunder
Re: Air Tank Size?
I was waiting for your comment XXL !!!
My Project 69 SWB
Old 11-16-2006, 09:09 PM   #7
XXL
Seņor Member
XXL's Avatar
Re: Air Tank Size?
Actually, I'm impressed. I can only jack it up and down once before my system is spent and I have to wait for it to fill up again.
Old 11-17-2006, 04:51 AM   #8
camaro__thunder
Re: Air Tank Size?
Well I use one of the huge nitrogen bottles and a manifold. PERV
My Project 69 SWB
