Old 11-15-2006, 02:29 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
help with a one piece oil pan gasket
i recently aquired a rebuilt 1989 350. im going to use a one piece oil pan gasket but there are 2 metal oil pan pieces that i have no idea what to do with. it looks like it would seal just fine without them. what do yall think?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 11-15-2006, 03:25 PM   #2
70rs/ss
70rs/ss's Avatar
Re: help with a one piece oil pan gasket
If I am thinking correctly (need picts to be fer sure!) Those two pieces go down on top of the pan rail to keep the pan bolts from warping the flange and causing a leak, so YES you do need them unless you want a potential oil leak.
70rs/ss is offline   Reply With Quote
Old 11-15-2006, 03:37 PM   #3
Bad71chev406sbc
Bad71chev406sbc's Avatar
Something like this????
Then yes...you need them. This pic was taken before the teardown of my 400.
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
Bad71chev406sbc is offline   Reply With Quote
Old 11-16-2006, 04:34 PM   #4
crm318
crm318's Avatar
ill try to get yall some pics. the two pieces run the length of the pan on either sides and look like the two piece gaskets (accept they are 1/8 in thick metal).
1972 Cheyenne
Old 11-16-2006, 04:46 PM   #5
70rs/ss
70rs/ss's Avatar
Yeah, I know what they look like, they are there to keep equal pressure on the gasket as I stated above, the metal keeps the pan lip from warping if you over tighten the bolts which will cause a leak and or the gasket to split! Use it, there is no benefit to not using them so it is a little insurance to prevent a leak.
Old 11-16-2006, 05:16 PM   #6
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 11-16-2006, 09:08 PM   #7
roj2323
i totaly agree. i have even added them to every engine i've ever built that didin't have them originaly. the only exception to this might be an aluminum pan as the edge is allready thickened.
roj2323 is offline   Reply With Quote
Old 11-16-2006, 10:52 PM   #8
rage'nrat638
rage'nrat638's Avatar
hell yea you need them
rage'nrat638 is offline   Reply With Quote
Old 11-17-2006, 03:56 AM   #9
Bad71chev406sbc
OHHH....I get it now.
