11-15-2006, 02:32 PM | #1 |
Alright Alright Alright
popping in the suspension
i have noticed lately that when i back out of a partking spot and turn the wheel. there is a loud pop i hear coming from the frame or suspension. you can also feel the pop. what might cause this?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
11-15-2006, 05:19 PM | #2 |
The Engine Whisperer
Re: popping in the suspension
Are you sure, that it isn't your rear-end thats popping? Had the same problem, when turning it would pop very loud and you could feel it.
11-15-2006, 05:45 PM | #3 |
TOTY 2006
Check your frame where the powersteering gearbox is mounted for any cracks in the frame, or have someone turn the steering wheel back and fourth while you have your head under the truck to see if you can see any of the suspension or steering components moving in an unnatural way....
Also check to make sure that your front brake calipers are bolted down tight. |
11-15-2006, 06:14 PM | #4 |
TTT for you since I noticed this on my truck last night.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-15-2006, 08:05 PM | #5 |
WTB this ad
My C10 wasn't popping but I could feel something shift when I was backing up with the wheels cut deep. My upper control arm bushings were shot! Might be worth taking a look at.
11-16-2006, 04:25 PM | #6 |
thanks guys. ill give it a look over.
11-16-2006, 08:46 PM | #7 |
I havent really driven my truck, but Ive noticed a couple times when getting in and out of my truck it pops every once in a while...
Btw crm318, nice avatar.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
