![]() Join Date: Jul 2006
Sticky lifters?
I posted this in the motor section also.
I recently installed a new set of aluminum Trick Flow Kenny Duttweiler heads, new intake and some stainless steel full fulrcom roller rockers. The motor sat for about a week before I finished and now even though the rockers are adjusted the lifters are still chattering a little. I let it set a couple of days and the lifters seemed to have pumped up a little. I am not sure what else to try to get them to quiet down. Could they be stuck or sticking? I just put some Marvel Mystery oil in the crank case hoping it will help. Any experience or advice is welcomed. Thanks, B-dub |
Senior Moment
![]() Join Date: Mar 2002
Re: Sticky lifters?
Big Block ? Small Block ? Need a bit more info
Could the rockers be hitting the valve covers ?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Re: Sticky lifters?
![]() I put a high-lift cam/springs in a buddy's engine that he brought over. He put the engine back in, but complained of a noisy valvetrain ![]() ![]() |
Re: Sticky lifters?
It's a sbc 350 .040 over. It makes this noise with the valve covers off.
Re: Sticky lifters?
I took a quick surf to the site in your .sig, and saw the pic with the broken valve spings - ouch. Have you checked for coil bind and looked at the valvetrain geometry. And, just to confirm - the new rockers are still the same ratio, correct?
Re: Sticky lifters?
New flat tappet cam? If so, did you break it in properly? You should be able to isolate the noise down to the noisy lifter(s).
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Woof?
Re: Sticky lifters?
Roller rockers are inherantly going to make some noise. If it's not rapping with the hood closed, you should be just fine. I've got 1.6 rollers on an LT-1, and they never shut up, despite being perfectly adjusted.
1968 LWB CST BB 2004 Avalanche Z71 LT3. 2003 S-10 ZR2 (hers). 1997 Astro 1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck. 1997 Saturn - need gas mileage from something! |
![]() Join Date: Sep 2005
Re: Sticky lifters?
did you soak the lifters in oil before you insatlled them?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#9 | |
Re: Sticky lifters?
Here's what I did. I had a running motor with world product S/R's and 1.5 roller tip rockers. I yanked those and through on the aluminum trick flows and a set of 1.6 full rollers. The cam, lifters and push rods are all the same as before. The rockers don't hit the valve cover. It makes the same noise on or off. I can back off the rocker stud bolt until it starts tapping and then tighten back up until it quits. Then 1/4-1/2 a turn. There is no rocker noise but there is still lifter noise. It runs great it's just bugging the crap outta me and I want to make sure that I'm not going to screw up a lifter if that is in fact what the problem is. |
Re: Sticky lifters?
I have to admit to some real worries given the 1.5 -> 1.6 rocker ratio change. Even on the car have you checked for coil bind at full lift? If this is happening the the only two points of "give" are the stud and the lifter.
I may be off-base here, but that was my initial concern and hence the continued questions about the rocker ratio. |
Re: Sticky lifters?
1.6 vs a 1.5 will increase lift considerably (at least enough to cause coil bind) what lift are the heads (springs) good to? You should be able to determine the lift after the 1.6 if you know the cam specs, then determine if the springs on the heads are OK, one other thing, there are lifters out there that rattle like nobodies business at idle but pump up under high revs (to help cut the lope of a big cam at idle) Rhodes makes some and there are others, does it quiet down going about 2-3k rpm?
Re: Sticky lifters?
Thanks for the replies guys...
Definitely not coil binding. These are 1.46" springs at 125lbs. of seat pressure at a 1.80 install height. I realize that the 1.6 ratio rockers will give me another .030 of lift. The cam is an extreme engery comp 268. .224 intake and .230 exhaust and .477 lift. I should be good there. I'm just thinking that maybe the lifters have a "memory" if you will and are not like the adding lift. Hmm..... |
#13 | |
Re: Sticky lifters?
The lifter is just a machine ![]() |
#14 |
Re: Sticky lifters?
I am fairly certain that I'm not coil binding. These heads are spec'd to handle .560 lift and I'm probably not even over .500 yet. They are the Trick Flow Kenny Duutweiler 23 degree twisted wedge aluminum heads. They already come with big springs, 7/16" screw in studs, guide plates and hardened seats.
Still scratching my head..... ![]() |
#15 |
![]() Join Date: Jul 2004
Re: Sticky lifters?
The 1.6 rockers will move the pushrod closer to the stud, is there clearance at the bottom of the pushrod guide plate slot ? Might need to check at closed, half-way and full lift since the clearance distance changes. I have also seen roller rockers that did not clear the valve spring retainer also, right where the arm meets the fulcrum on the under side. They had to be machined down in that area a little to clear.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#16 |
Re: Sticky lifters?
Wow....
Very good points to check. Lemme take a look and get back to you. Thanks, B-dub |
#17 |
Re: Sticky lifters?
O.k....
So I've done some more research on this. I contacted comp cams and they said that the extreme energy series cam is noisy by nature because of how fast the exhaust valve slams shut. Also, they mentioned that the pro-magnum roller rockers are also noisy by nature. Those 2 factors combined with an aluminum valve covers is making the noise louder. I don't care as long as I'm not hurting anything. Thanks for all of the responses. B-dub |
#18 |
Senior Moment
Re: Sticky lifters?
That’s exactly why I threw away the &^%$#@ Comp Cam I had in my Big Block and went with Lunati. Better performance and WAY less noise
Just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 11-17-2006 at 03:29 PM. |
#19 |
Turbo Guy
Re: Sticky lifters?
Just curious, did you set the lifters cold first? You mention doing it while the engine is running backing off til it raps and giving a 1/4 turn. Just my 2 cents but doing them cold seemed to be more consistant than hot to me in my experience
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles. 1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit! Things I've broken so far: 12 bolt diff saginaw 4 spd many, many pieces Aluminum case Super t-10 4 spd |
#20 |
Re: Sticky lifters?
Initially I set them with the motor off. Then after getting it started and hearing the noise I started to do them with it running. HUGE mess and I HATE doing it that way. Ugh........
