Old 11-15-2006, 05:05 PM   #1
GR82BME
GR82BME's Avatar
Power steering
Hey guy's, when converting manual steering to power steering, is it true all i need is the adapter plate and any newer set-up of a 2 wd chevy truck to go on my 62, pitman arm and all should work just fine? Thanks
GR82BME is offline   Reply With Quote
Old 11-16-2006, 01:28 PM   #2
60-66 Nut
Professional Beer Tester
Re: Power steering
I think you also need to replace the pitman arm and also shorten the lower steering column shaft.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 11-16-2006, 06:38 PM   #3
Shorty Cox
Re: Power steering
This has been covered many times on the board. I know on a '64, all you need is a steering box, hoses, and pump from a later model truck. Don't need to change the pitman arm. I got it off a '85 truck. It can be done with or without a bracket. I did. But a bracket makes it easier. Yes you have to make the steering shaft shorter. Best $160.00 i've spent on my truck.
Shorty Cox is offline   Reply With Quote
Old 11-20-2006, 10:53 AM   #4
GR82BME
GR82BME's Avatar
Re: Power steering
Thanks for the info. guy's
