Old 11-15-2006, 09:29 PM   #1
griesel72
griesel72's Avatar
camaro tach hook up?
I have a 72 that already had a camaro tach installed, but there is no wires hooked up, i found the wire going from the hei to the tach, but what does the other wire hook to? Is it a ground?
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 11-15-2006, 10:48 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: camaro tach hook up?
The back of the tach should be labeled. There should be one labeled 12V another labeled coil and then one for the ground.
see ten is offline   Reply With Quote
Old 11-16-2006, 12:28 AM   #3
STP67-72
STP67-72's Avatar
I have a camaro tack setup that this man used to build a lot of them. My brown wire goes to the tack on hei. My red goes to fuse box that is hot when key is on. Hope this helps.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
