11-15-2006, 10:31 PM | #1 |
better booster
has anyone swapped in a smaller and better looking booster and master cylinder. somthing that dont stick out off the firewall so far.
11-15-2006, 10:36 PM | #2 |
Re: better booster
forgot to mention my truck is a 72 1/2 ton 2wd with power disks, and im going to be running a 454 with a little higher compression. im getting a vintage air kit to replace my stock bulky ac and would like to clean up the other side a little.
11-16-2006, 01:01 AM | #3 |
A guy with a truck
Re: better booster
Workin' on an '85 Pontiac Fiero unit. Pics will follow...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-16-2006, 01:16 AM | #4 |
Chevy Truck Addict
Re: better booster
I installed a newer "pancake" style booster on my truck (don't know if that is the right description). It's not tiny but it is a lot more compact than the factory boosters with the coupler attached to them. The brackets are a lot shorter and the booster itself is only 3 inches thick.
There are some more pics and info on this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=215980
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
11-16-2006, 10:57 AM | #5 |
Chief Honcho In Charge
Re: better booster
Does that master cylinder not lead to a proportioning valve? Is there a setup we can use with no separate proportioning valve..or one built in?
I really do not prefer that proportioning valve hanging out there in the air...it really is ugly...functional but ugly.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
11-16-2006, 11:23 AM | #6 |
Chevy Truck Addict
Re: better booster
I didn't really care for the "factory" position for the proportioning valve either so I built a bracket and mounted it on the inner fender below the master cylinder.
I may move it again and mount it on the cross member like in the 73-87 trucks.
11-16-2006, 05:36 PM | #7 |
Wrenchin & Sandin!!!
Re: better booster
Not tryin to hijack you're thread but I have a question......since I've already replaced the master cylinder on my 71 does this mean I have to get the booster to match the application or can I get a different one?
Randy Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG |
11-17-2006, 08:48 AM | #8 |
blood type; Retumbo
Re: better booster
I had to do a little fabbing but I am using a booster from a early 80s on mine. I mounted the combo valve on the forward Xmember (under radiator)
11-17-2006, 04:10 PM | #9 |
Re: better booster
I have a booster and mastercylinder i'd bought for my 84 camaro, and since i no longer have that car, it's goin in the truck.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
11-17-2006, 04:42 PM | #10 |
Re: better booster
Guess my question is do certain master cylinders only work with certain boosters? I put a new stock MS on my 71 and now I need a booster. Can I get one from a 3/4 or 1 ton or do I need one for a 1/2 ton so I don't need to change out the MS again?
11-17-2006, 05:30 PM | #11 |
The Engine Whisperer
Re: better booster
Theres a shop here north of Columbus called Right Stuff Detailing, and they make nice brake booster and master cylinders that are show quality, and you can get them for low profile apps., they also do alot of other stuff. If you want brake lines, that make them all for 67-72s. So I would give them a look over, their site doesnt have any pics, but if you get their catalog is plenty of pictures and information in there.
www.rightstuffdetailing.com |
11-17-2006, 06:04 PM | #12 |
Re: better booster
Im doing the same thing. My buddies been putting these fiero units in 50-72 trucks for many years, plus there in all the boneyards. Im using the electric radiator fans out of this model as well
70 GMC shortbed fleetside with a 72 chevy costume Last edited by 72dually; 11-17-2006 at 06:09 PM. |
