11-16-2006, 12:32 AM | #1 |
Oilfield Trash
Big Block/TH400 Guys, I Need A Pic Please
Tryin to get all the parts together to turn my 70 3/4 ton 350 back to an oringinal 402 big block, wondering if i could get a pic of the throttle linkage, and any kind of kickdown linkages and stuff. I was looking in the service manual and saw several different linkage combos and an electric kickdown switch, mine seems to have none of these. I want to turn this truck back to stock, since the only thing ever done to it was a 350 swap by the PO due to a blown motor. So any pics of factory style big block resto's would be great, thanks, Ryan
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
11-16-2006, 11:49 AM | #2 |
Oilfield Trash
Re: Big Block/TH400 Guys, I Need A Pic Please
Must been some factory guys on here
11-16-2006, 01:06 PM | #3 |
This is a pic off an ebay ad that might help. I don't think the bigblocks used any kickdown linkage but some kind of solenoid switch instead.
11-16-2006, 02:30 PM | #4 |
Oilfield Trash
thanks man!
11-16-2006, 03:35 PM | #5 |
I went and looked at my 72 truck and it looked the same. That big solenoid looks like an a/c idle up.
11-16-2006, 04:08 PM | #6 |
Is this what you're looking for? It's on my 69 and I don't know if it's the same as a 70.
69 Chev C20 396 T400 Dana 60 3.54 A/C Daily Driver - Stolen 67 Chevy C20 CST |
11-16-2006, 08:39 PM | #7 |
Here is a pic of the kickdown switch as mounted on a Q-Jet carb.
Jim |
11-17-2006, 12:45 AM | #8 |
My 71 looked almost exactly like the one in the pic from Texas C10. The solenoid has nothing to do with AC as mine was not an AC truck. There is no kick down switch for the TH400 on a 71 or 72. Can’t say about the 70 though.
Enjoying life again. Time to get those big blocks rolling. |
11-17-2006, 09:30 AM | #9 |
It is weird my 78 has nothing on the carb at all. My 72 looks like the first picture. Both trucks have TH400s and AC. I have no idea how the TH400 kickdown works.
11-17-2006, 09:40 AM | #10 |
Here is a picture of the kickdown switch for the TH 400 as used on the 71-72 trucks. It is mounted inside the cab above the accelerator pedal.
Jim |
11-17-2006, 09:41 AM | #11 |
the turbo400 uses a electric kickdown the thing bolted to the base of carb is activated at wot and sends 12v to the spade connector on drivers side of trans u can do away with that big swich and use a mini microswitch like the ones used on a nitrous system 12v coming in to swithc and 12v coming out a wot
11-17-2006, 10:47 AM | #12 |
Thanks Jim! I will check my trucks for that type of switch.
11-18-2006, 12:54 PM | #13 |
Both my 78 and 72 C10 have that same kickdown switch.
Thanks for the info and sorry to have highjacked! |
