11-16-2006, 12:57 PM | #1 |
2wd conversion
I just purchased a 72 blazer 4x4 and want to convert to a 2wd I already have the front suspension, the rear trailing arms and crossmember, rear axle and coil springs how and where can I get the right measurments for the placement of the rear trailing arm crossmember any help would be greatfull
thanks |
11-16-2006, 01:35 PM | #2 |
SKINNY TIRES RULE!
Re: 2wd conversion
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
11-16-2006, 08:25 PM | #3 |
Re: 2wd conversion
thanks for the tip.
11-16-2006, 08:56 PM | #4 |
The LuvShack Garage
Re: 2wd conversion
From West TN
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-16-2006, 10:32 PM | #5 |
Re: 2wd conversion
Edited by Moderator
11-16-2006, 11:13 PM | #6 |
Re: 2wd conversion
the way idid it was to mount the trailing arms to the axle, then center the axle in the wheel opening. i mounted the trailing arm crossmember and measured to make sure everything was sqyare to the frame, then i drilled the holes for the crossmember and mounted it with grade 8 bolts. the biggest challenge was the coil springs, since the 2wd frame flares out over the axle as opposed to the 4wd frame which is pretty much paralell all the way back. if ytou have some fab skills you can make a mount to support the coil springs
if you got anymore questions feel free to email me. i am gonna remove the trailing arms in favor of a 4 link since i decided to go lower.
11-17-2006, 09:36 AM | #7 |
Happy to be here
Re: 2wd conversion
Is there are reason to convert the rear to trailing arms and coil rather than leaving the leaf spring and flipping them under the axle?
11-17-2006, 10:25 AM | #8 |
Blazerless
Re: 2wd conversion
Trailing arms and coils ride and handle alot better than leafs. The trailing arm suspension in the trucks is the same basic suspension modern nascar stock cars use! It's rumored GM put this suspension in the trucks so it would be legal for nascar use.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD 69' Beaumont 388/700R4 11.70@116 77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad. |
11-17-2006, 07:26 PM | #9 | |
Happy to be here
Re: 2wd conversion
Beyond that is there a reason to hassle with a major conversion rather than just flipping the springs and being done with it?
11-17-2006, 07:29 PM | #10 |
The LuvShack Garage
Re: 2wd conversion
It's easier to flip & bag the springs you got, than to swap it all out, jmho
11-17-2006, 08:49 PM | #11 |
Re: 2wd conversion
I'm getting back more feedback than I thoughtand I'm truely thankful, even though I decided on using the trailing arms I'm just being different
11-18-2006, 04:50 PM | #12 |
Re: 2wd conversion
I just located a 68 shortbed frame I know that it's a little longer than a blazer frame but could I just swap out the body or is it more of a headache case I'm also thinking the body mounts being in a different location than the blazer, And how much more would the frame stick out the back?
11-18-2006, 05:07 PM | #13 |
Re: 2wd conversion
You would have to shorten the wheelbase by 11" IIRC. Then you have to figure out body mounts and such. I'm getting ready to convert a 4x4 frame over to 2wd, to me it just seems easier to use the original blazer frame.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
11-18-2006, 05:19 PM | #14 |
Designated A-hole!
Re: 2wd conversion
Take a lot of pics and write a FAQ for us.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
