Old 08-17-2002, 08:28 AM   #1
hjalbert
cracker
hjalbert's Avatar
hopefully last thing HELP with adding rear DIFF oil
on my rear diffeential, i have this plug under the half way point, then on top i have this 3/8 inche fitting, that opens up into the rear diff, nothing covering it, it was packed up with grease. i am thinking that is where i add fluid, but havent seen anything like that before, was wondering if anyone else had, it is on the top to the passengers side, pointing up. its about 1/2 inch long, was guessiiing one of the previous owners broke the plug or something and put that in to make it easier to add fluid. thanks harry
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 08-17-2002, 08:44 AM   #2
jhow66
jhow66's Avatar
plugs
The plug on the side is where you add oil--fill to bottom of hole. The deal on top is the vent for the rear gear case--it should have a hose attached to it and affixed to the bed. This keeps water from entering the case when driving in the rain or thru deep water. Hope this helps.
www.geocities.com/jhoww66/2-.html
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-17-2002, 10:12 AM   #3
hjalbert
cracker
hjalbert's Avatar
in that case then i guess the only way to drain it would be to take the diff cover off? to bad the plug is all busted up, i cant get a goodgrip on it. oh well, looks like ill have to figure something out thanks harry
1972 GMC JIMMY,
1999 bmw k1200 ltc
1991 bmw k75
