Old 04-22-2002, 07:50 AM   #1
guyryan100
guyryan100's Avatar
Post Time to put 'er in gear? It's been 5 years . . .
Ok, there is a very remote chance that I will finish my brake-overhaul on saturday. If that happens, I will be VERY tempted to throw the ole' beast in gear and see if it moves (it hasn't moved for 5 years).
What, if anything, should I do with the transmission before I attempt a short drive forward? I know the truck was well-maintained up until the time it was parked in 1997, so the trans. fluid would not have been old at that time. I also know that the transmission worked without any trouble up until that time.
I have never done any transmission work before, so rebuilding it would probably be out of the realm of possibility at this time.
I really hope the board will suggest that I just drop it in gear and see what happens!!
Oh, it's a '67 C10 with a 3 on the tree.
Thanks for your suggestions!
guyryan100 is offline   Reply With Quote
Old 04-22-2002, 08:10 AM   #2
69 longhorn
Post
I would say,just check fluid level,then pull it through the gears a few time while shes warming up,& check for any leaks before you take off. Good luck.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-22-2002, 08:45 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Pop the clutch!
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-22-2002, 08:48 AM   #4
69 longhorn
Post
D@mn.....I had a big brain fart! I didnt read the 3 spd stick part........69
Old 04-22-2002, 10:23 AM   #5
guyryan100
guyryan100's Avatar
Post
What are the chances it will actually move . . ?
Old 04-22-2002, 10:26 AM   #6
Longhorn Man
Post
Have faith man, let the clutch out slowly and smothly so it'll lightly rub the rust off instead of grind it into the clutch material.
5 years is Just a break. Giv it some fresh fluids and a tune up,(maybe tires too) and you could go for a long drive w/o problems IMO.
Old 04-22-2002, 12:55 PM   #7
Fast68Chevy
Fast68Chevy's Avatar
Post
it iwl move, dont worry about the tranny, worry about brakes and engine and tires and such
Randy- Lincoln, IL
r68c30@hotmail.com
-71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not)
-84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,,
-84 Firebird SE 2.8L T-5, rod knocking, dammit,,
-82 Firebird 350 4bolt (TBL)/TH350, not running, dammit...
buy/sell/hoard/trade most any GM vehicle parts of any kind
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 04-22-2002, 08:20 PM   #8
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
I put a 3spd trans in the convertible that had been on a shelf for 10+ years, all I did was put new seals in it, filled it with oil and backed it out of the shed.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-23-2002, 10:48 PM   #9
69underburban
Post
I have been gone a while and just checking in on the site and know this is old news but I bought a 69 sub that had been still since 92. Iput a fuel pump on it shot some starting fluid in it turned the ignition. The old starter grunted a few times and fired up my gosh you never seen the likes a smoke come out of a tail pipe. Dropped it in gear drove it out of the field (after we took the tires and had them aired up).My buddy followed me home and I drove real slow until I found out if the brakes were o.k. That was 5 months ago and been fixin' on it every day a little bit at a time. But boy are those 1/4 in bad shape. Good luck to ya!
baaadly needin'rear 1/4's
69underburban is offline   Reply With Quote
Old 04-23-2002, 11:13 PM   #10
69underburban
Post
Oh Yeah it kinda jumps and jiggles and shakes and wobbles when I let out on the clutch but hey it moving. I might would to if I sat that long.
Old 04-23-2002, 11:15 PM   #11
Longhorn Man
Post
Mine does that when ever it's in motoin. That reminds me...I need some front tires.
Old 04-24-2002, 12:19 AM   #12
O'l Buck
O'l Buck's Avatar
Post
speaking of vehicles sitting around for awhile, my poor old cutlass convertible had been parked in a shed for 15 years, I aired the tires up, pulled it to my friends shop, put one of his batteries in it, filled with water and prestone, added 1 quart of oil(the engine already needed rebuilt), poured gas in the carb, hit the switch and she ran beautiful, a little smoke(skeeter killer) but circled the truck lot like she'd been driven everyday, except for the brake thing, but that's all new now, along with the engine. best free car I ever found!!!!
330, 3spd stick
350/auto
Chad Stephens
Orleans,NE
Chad
