Old 11-16-2006, 07:15 PM   #1
Dean
Dean's Avatar
Need help with tilt column
Ok i'm doing a body swap on a 87 K30. To make things harder the body I'm using is from a manual trans truck while the K30 is a turbo 400. Neither one originally had the tilt column.
Now my electrical questions:
1st Where does the black wire coming from the turn signal/wiper/delay wiper lever hook up to? Neither truck had the delay wiper option before.
2nd I'm assuming I will have to change out the fuse boxe and wires since one truck was a 4 speed and now will be an auto. I'm looking for the wires the go to the neutral/reverse switch at the base of the column. I think I found the neutral wires on the 4 speed body but not the orange/black wire for the other one.
Not even mentioning the fun part cutting holes in the roof for the 1 ton cargo lights......lol
I'm wanting to get this thing together so I can actually start this new 572....
Dean is offline   Reply With Quote
Old 11-16-2006, 11:08 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Need help with tilt column
Dean-
I not totally sure, but I'm guessing the black wire from the wiper/directional switches is a ground and should be spiced with the other black wires running to the Bus Bar Ground.
I'm not so sure whether or not you have to swap out the fuse box. The wiring for the backup switch may be dark blue and light green?.
...572
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 11-17-2006, 09:25 AM   #3
Dean
Dean's Avatar
I found a dark blue and light green wires because they used to go to the four speed sensor, but I haven't found the orange with black stripe and black with white stripe that are also together and go to the switch. Probably have to switch them to get it all straight.
You are probably right about that black wire being ground.
Old 11-24-2006, 08:19 PM   #4
Dean
Dean's Avatar
Well I did go ahead and switch the who electrical harness between the trucks. That works much better except the 87 had a lot of computer plugs which I'm sure aren't needed for what i'm doing anyway.
Still wondering about the one black wire the turn signal/wiper lever. I agree it is most likely a black ground but where does it hook up to? It has a strange male fitting on the end.
Old 11-25-2006, 12:24 AM   #5
magnethead
7000 #'s of american IRON
magnethead's Avatar
Is it a bullet (baarrel) connector?
magnethead is offline   Reply With Quote
Old 11-25-2006, 09:35 AM   #6
Dean
Dean's Avatar
It is a flat connector.
Old 11-26-2006, 09:10 AM   #7
beaterC10
Does the column have a cruise control switch? Cruise normally hase an extra wire with an odd connector.
beaterC10 is offline   Reply With Quote
Old 12-20-2006, 07:01 PM   #8
Dean
Dean's Avatar
The tilt does not have cruise control. This wire comes out of the turn signal/delay wiper switch on the left side. My two previous trucks i'm using did not have tilt or delay wipers so I'm not sure where this wire goes. I guess it is a ground but it is a different wire end. Any ideas?
Old 12-21-2006, 10:23 AM   #9
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I don't know what it controls, but that is the only wire/connector coming out of my stalk on my '86 with cruise and delay wipers. It plugged in somewhere near the bottom of the column. I wish I could remember more, but that was a couple of years ago.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-06-2007, 03:00 PM   #10
gotmud
gotmud's Avatar
Did you ever figure out what the flat black wire was far? I have the same question. Im using the 86 column in a 64 restorod and cant figure it out either.
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 01-06-2007, 06:21 PM   #11
84 400
Sb 400 club
84 400's Avatar
well on mine the wipers work fine but the cruse does not and that black wire is cut. but it may dal with the intermitant wires as thouse don't work on mine eather.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-08-2007, 04:42 PM   #12
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
That is the cruise control wire.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-08-2007, 09:09 PM   #13
Dean
Dean's Avatar
I don't have cruise installed on the truck but everything else works good so I think you guys are right as usual. Thanks again!
