11-16-2006, 09:07 PM | #1 | |||
Union Electrician
67 only radio area patch
I have a 67 only dash radio area patch cut in behind the cluster area an over into the glovebox. Will ome to you cleaned out unless you want the radio and ashtray, the ignition switch IS NOT included. $25 plus shipping.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
11-16-2006, 10:20 PM | #2 |
Insert Title Here
Re: 67 only radio area patch
what makes it a 67 only
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
11-16-2006, 10:23 PM | #3 |
Randy churchill
the ingintion switch hole, 68 and up had a large bezel. 67 had a small bezel around the switch
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires 2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10 2003 Jeep Rubicon 4.5" short arm lift 1985 Jeep CJ7 30k in parts and still adding up |
11-16-2006, 10:31 PM | #4 | |||
Union Electrician
Correct soulman!!
11-16-2006, 11:48 PM | #5 |
Member #1049
The 67 ashtray is also wider than the rest..
11-18-2006, 08:10 PM | #6 |
Will the ignition switch area be undamaged?
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
11-18-2006, 08:46 PM | #7 | |||
Union Electrician
yes it will be carefully removed as this is one of the only surviving pieces of the original truck I have they key I got from Frank's wife that he had for many years and want to reuse it.
11-19-2006, 06:09 PM | #8 |
What do you want for the radio, does it work? J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-19-2006, 07:15 PM | #9 | |||
Union Electrician
The radio looks like crap, and I don't know if it works or not, but I have to assume NO as nothing else in the truck did
11-19-2006, 07:52 PM | #10 |
PM sent J.
