Old 11-17-2006, 02:46 AM   #1
skokie
skokie's Avatar
700r4 with a qjet
Is anyone running a 700r4 with a qjet? How did you hook up your tv cable to the qjet linkage?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-17-2006, 07:16 AM   #2
Werewolf
Woof?
Werewolf's Avatar
Re: 700r4 with a qjet
Some GM's actually had a throttle/ TV cable adapter plate that bolted between the back two carb bolts, and came off with the carb. Of course, after typing this, I realized you were talking about the cable connection. So I can't read, so what...
I believe my old '67 (actually a stock 2 barrel) used one of those very small brass block cable crimps, the one where you slide the cable through and then tighten a screw to keep the cable in place.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 11-17-2006, 10:37 AM   #3
Livrat
Member #1049
Livrat's Avatar
Here is the easiest way..
http://www.tvmadeez.com/1910_cam/
Livrat is offline   Reply With Quote
Old 11-17-2006, 01:23 PM   #4
skokie
skokie's Avatar
Thanks for the link. After looking at that I realize that my throttle linkage is different. It has more of a square end to it at the bottom. I think I will call and see what they have.
68 build thread
