Old 11-17-2006, 08:54 AM   #1
68C15
blood type; Retumbo
68C15's Avatar
quick question
are the lower arms interchangeable between a 68 and an 80? specifically the shaft diameters.
TIA
Todd
68C15 is offline   Reply With Quote
Old 11-17-2006, 11:05 AM   #2
craig@ridetech.com
Formerly LSC71
Re: quick question
Those arms are interchangeable, the only thing that will not be is the lower balljoint if you are still using the 68 spindle. If you have a 71 or newer spindle (disc brakes) the 80 balljoint will work.
craig@ridetech.com is offline   Reply With Quote
Old 11-17-2006, 02:13 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
Re: quick question
thanks. I have 68 arms with 80 spindles and joints. but I need to replace the arms due to irreversible damage.
Old 11-17-2006, 03:54 PM   #4
craig@ridetech.com
Formerly LSC71
Re: quick question
yep you should be fine. Like I said the big thing to make sure that your balljoints match the spindle you are using.
