Old 11-17-2006, 12:56 PM   #1
muddpile
muddpile's Avatar
Replacing hinge pins/bushings?
What is involved in replacing the pins/bushings in the door hinges? I have the new parts, but don't want to wreck anything in the process. Thanks!
muddpile is offline   Reply With Quote
Old 11-17-2006, 01:08 PM   #2
70GMCer
70GMCer's Avatar
Re: Replacing hinge pins/bushings?
Best way on doing this is to remove the doors and then remove the hinges. I sprayed them with WD40 & let set overnight. Then put them in a vise to hold, while taking a center punch and knock out the old pins. You may have to really hit the pins to come out. The old bushings will come out easy after that. Just reassemble. oh, make sure you mark the hinges on the doors and the cab with a marker before removing the doors, so it will be easier to put the doors back on when you finish. This has always worked for me. Others may have a different way.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-17-2006, 02:53 PM   #3
Green Machine
Green Machine's Avatar
On the replacement sets I have gotten the pins are too long, to look the best they can be sawed off with a hacksaw then touchup on bench grinder, or if the old pin are good they can be reused. Most sets have brass bushings to replace the plastic ones.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-17-2006, 06:54 PM   #4
muddpile
muddpile's Avatar
That's what I figured I'd do, but I thought I'd make sure. The old ones are really wobbly, so I will be replacing the pins and bushings. I don't need to worry about marking where the hinges go, as the truck is getting new doors. Thanks!
Old 11-17-2006, 07:08 PM   #5
Fastfun
Fastfun's Avatar
Here is a link on how to change bushings
http://www.earlyclassic.com/tech.asp...le%20Rods%20P9
Hope it is what you are looking for
Fastfun is offline   Reply With Quote
Old 11-17-2006, 07:20 PM   #6
70GMCer
70GMCer's Avatar
I was surprised how good my pins where after taking them apart. I reused the pins in mine.
1997 GMC Sierra Ext
1965 Mustang
