Old 11-17-2006, 02:05 PM   #1
pkj
dump and fill valves
is the same type of valve used for both dump and fill? how do these valves work? part of the fun is trying to find something on the cheap and making it work. so i am thinking that there may be some type of valve that is designed for something else but would work. if it has a high usage and no wow factor name=less money. thanks, pkj
pkj is offline   Reply With Quote
Old 11-17-2006, 02:19 PM   #2
Shane
Shane's Avatar
Re: dump and fill valves
they are the same ... you are not the first to try to do this "on the cheap" ... save yourself some time, effort and money and just buy them. honest.
Shane is offline   Reply With Quote
Old 11-17-2006, 02:20 PM   #3
abadsvt
abadsvt's Avatar
I am not expert but i believe i am pretty sure that they are used for both dump and fill. When i bought my valves i got 8 of all the same valves so they must be the same more i think about it. As for what else you can use that is up to you. I have no idea. I bought mine from suicide doors and i believe they are about $30 each. Good luck!!!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 11-17-2006, 03:23 PM   #4
b&a72
Active Member
b&a72's Avatar
There is many different kind of valves I run 4 4 way solenoid valves. They are a little expensive but it saves the cluster of having a bunch of 1 way or 2 way valves.
b&a72 is offline   Reply With Quote
Old 11-17-2006, 03:43 PM   #5
pkj
so are these just a solenoid that open and close by an electric circuit? thanks,pkj i guess i will never stop trying to re-invent the wheel!
Old 11-17-2006, 03:59 PM   #6
b&a72
Active Member
b&a72's Avatar
You are right but there is valves that are normally open or closed so make sure you buy the right ones. If you buy them from Suicide they are the correct ones.
Old 11-18-2006, 10:20 AM   #7
LuckyHG
LuckyHG's Avatar
Get some GC's or something designed for it. I definately understand where you are coming from tryin to find some kind of cheap replacement. Cheap valves are a pain in the ass though. They leak and your truck will end up going higher or lower on its own. Then you gotta rip them out of wherever there hidden and buy new ones anyway. I think Suicide doors still has a good deal on some quality ones. Oh and they can be used for fills and dumps the same, just follow the directional arrow on them when installing.
71' 2wd sub <------parts donations accepted
99' 4wd big block sub
92' K2500 ext cab Lb
95' S-10 sfbd, hydro's, etc.
02' Ram bagged etc.
83' International School bus...flat black with alot of room
www.Homegrowncustoms.com
LuckyHG is offline   Reply With Quote
Old 11-18-2006, 05:41 PM   #8
jimmydean
jimmydean's Avatar
I bought 2 different sets of 4 off ebay for a wicked good deal. To keep things simple, I used one brand for fill and one brand for dump. All 8 are good quality valves, but buying them the way I did, I saved about $100. I would have saved even more had I known one set I got didn't include the wires. That was $30 and a huge pain in the ass to find.
When it was all said and done, I would have spent a little more, but would have done a lot less work had I just went with Suicide Doors in the first place. I can't say enough about how great they have been with advice and support.
jimmydean is offline   Reply With Quote
