Old 11-17-2006, 04:03 PM   #1
Ram-Man
Ram-Man's Avatar
Paint on new spindels
Are you guys painting your new spindels?? Or do they have some sort of rust protection on them???
Ram-Man is offline   Reply With Quote
Old 11-17-2006, 04:08 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Paint on new spindels
I didn't paint my ECE ones when i put them on
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 11-17-2006, 04:11 PM   #3
68 short step
they have rust protection on them, but after a drive in the rain they will rust unless you paint em
68 short step is offline   Reply With Quote
Old 11-17-2006, 10:04 PM   #4
71see10
Worthless
71see10's Avatar
Painted mine, hope this stops the rust!
71see10 is offline   Reply With Quote
Old 11-18-2006, 01:35 AM   #5
nandress
nandress's Avatar
They won't rust, per se, but over time they will develop a handy "patina" that won't look quite as cool. These are cast iron with steel spindles (which won't corrode with a happy encapsulation in grease) so you have to do something.
Painting will work, but over time will flake off. I recommend powder coat. For two spindles it would be very inexpensive, plus be darn near impervious. Just make sure you have them masked real well, or else you can look forward to a couple hours with a file refitting all the tolerance parts. Be careful of the parts where the calipers slide, as you might not realize just how tight a fit that is until you have had to clean off the powder coat to make them fit again.
nandress is offline   Reply With Quote
Old 11-18-2006, 08:21 AM   #6
mac
Active Member
mac's Avatar
I used Rustoleum "HAMMERED BLACK". Its a textured finish thats tough as nails. I used it on all of my suspension parts and it stands up on a driver just fine. Its easy to touch up but really never needs much. $5 a can at Lowes.
mac is offline   Reply With Quote
