11-17-2006, 06:07 PM | #1 |
Corvette wheel in 72 C10
I picked up a 3 spoke rally wheel on the cheap and now trying to find out how to adapt it to my stock stearing column. Let me know if you have any pointers?
thanks |
11-17-2006, 06:28 PM | #2 |
The LuvShack Garage
Re: Corvette wheel in 72 C10
1st. From West TN
2nd - Does it look anything like this one pictured below?
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-21-2006, 10:00 PM | #3 |
Thats the one. What adapter did you use to make it fit and where did you get it??
thanks, |
11-21-2006, 11:44 PM | #4 |
Apparently a 69 Camaro hub kit will work on our columns, and I was told that a 68 Camaro hub will work as well, and match the size of the column better. That being said, I mentioned this on the board awhile ago and IIRC someone had tried the 68 hub and ecountered problems. Hopefully they will chime in and set the record straight.
"You can take the man out of PA, but you can't take PA out of the man" |
11-22-2006, 12:22 PM | #5 |
I have never had a problem using the 69+ hubs (genuine GM) that I find at the junk yard. The 68 Camaro hub that I bought (a repro) has issues. I don't know if the issues are because it is a 68 or because it is a repop. It doesn't seem to go down on the shaft far enough to fit nicely.
The 69+ hubs are only a little bigger in diameter at the bottom. When installed they are about 1/8th inch larger than the column (hardly noticeable). Hubs are readily available from Camaro or Chevelle repop vendors along with the horn contact and center cap.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
11-22-2006, 06:37 PM | #6 |
Out of the carpool lane.
I have an extra hub for a Camaro if anyone would like it for the cost of shipping. I don't know what year it is but I could find out specific dimensions if needed. Years ago I bought a Grant wheel that had been on a Camaro and the hub came with it. I have NO desire to put a Grant wheel on MY Camaro!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-22-2006, 08:05 PM | #7 |
Brad - Is it a GM hub or a Grant hub?
