Dash Knobs
I have to get my dash out for wiring repair. I know the washer knob has a set screw. How does the headlight knob come off? Chanel locs? TF
Four Wheeler
To remove the headlight knob....
Reach up behind the dash to the approx. location of the headlight knob. On the top of the switch box (for lack of a better term) you'll feel a spring-pressure button. With the headlight knob pulled out (as if the headlights are on), push the spring button down... and pull the headlight knob right out. (Don't forget to unhook the ground cable on the battery or else your lights will stay on!) Then just remove the bezel nuts. Those little chrome rings that go around each knob.... That's it! You're done!
'84 K20 4x4 350 V8 - Weiand intake - Headers - 4" Tuff Country lift - 35x12.50 ProComp M/Ts on 15x10s |
Thanks for your help. Here they go. TF
