Old 08-17-2002, 02:54 PM   #1
Russ72C10
Four Wheeler
Russ72C10's Avatar
Rear mount gas tank question....
I'm looking at the entire "kit" from Brothers. My question is... does the kit include EVERYTHING I will need to complete the swap? If anyone else has done this.... what other little parts might be necessary aside from what's in the kit? I'm thinking this will be a weekend project for me soon. Also.... without removing the bed, just how big of a PITA will this be?
Here's a link to the one I'm thinking of buying...
Rear tank kit
Thanks guys (and gals)
'84 K20 4x4
350 V8 - Weiand intake - Headers - 4" Tuff Country lift - 35x12.50 ProComp M/Ts on 15x10s
Russ72C10 is offline   Reply With Quote
Old 08-17-2002, 03:51 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Rear mount tank kits normally come with tank, straps ,anti-rattle strips and pick-up.This means that you will need to address the filler neck and do something for fuel lines,and the wiring for the guage.There may be something I'm not remembering so hopefully someone else will reply if I have forgotten something.You may want to install the tank and do the filler and run the lines over a few weekends so that all the major portions are done and you just have to hook all the components up on the actuall"install" weekend.Exspecially if this is your daily driver.
One option on the fuel lines is to use a 'burb fuel line replacement kit(if you are doing a LWB).Check out Tennmans filler behind the sidemarker if you want a trick filler.Some people use a boat filler in the bed floor.
Check with the kit dealer/manufacturer to find out exactly what comes with the kit.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-17-2002, 05:04 PM   #3
Russ72C10
Four Wheeler
Russ72C10's Avatar
Thanks for the information! Sounds like you may be right about spreading this out over a few weekends. I'm also wondering if it would be worth the effort to remove the bed for the install... versus crawling around on my back. The sidemarker gas tank filler is exactly what I had in mind for the gas tube placement..... seems I have some serious thinking to do!
Thanks again!
(PS - anyone else with experiences? I'd love to hear them!)
'84 K20 4x4
Old 08-17-2002, 08:17 PM   #4
Low69CST
Go to my website and look for the blazertank link. I put this in my frame last summer.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
