Old 11-18-2006, 03:24 AM   #1
71Rat
ran out of money
71Rat's Avatar
control arm differences?
whats the difference from a pre 71 front control arm compaired to a 71-72 control arm? i know 71 and 72 was disk front but i didnt know the control arms were differnt and as i look up part numbers and products there is a split at 70-71. if someone could shine the light on this for me that would be great
71Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 11-18-2006, 12:04 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: control arm differences?
The steering stops differ on the 70 & older lower a arms You can use the older arms with disc spindles, just use the ball joints/tierods for the year of the spindle. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-18-2006, 12:10 PM   #3
71Rat
ran out of money
71Rat's Avatar
ok so the steering stops are the only difference, thats good news.... i am building another truck and wanted to do tubular control arms and just noticed the split in years for aftermarket control arms.
thanks a lot crazy longhorn
71rat
