11-18-2006, 04:22 AM | #1 |
GMC vs Chevy
I was wondering how compatible GMC and Chevy 67-72 trucks were. I might get a 67 gmc and I have a 69 chevy. Both are lwb and I was hoping I might be able to interchange some parts to get a whole truck. I primarily need a cab for my 69, would the 67 gmc cab work for the chevy? What other problems might occur in combining two of these trucks?
11-18-2006, 04:29 AM | #2 |
KEEP ON TRUCKIN'
Re: GMC vs Chevy
Everything is the same from the fenders back. To change grills you need to swap core supports. Someone else chime in if I am wrong about the grill and core support.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
11-18-2006, 07:47 AM | #3 |
Rottenwood Garage Member
Re: GMC vs Chevy
Rear suspension might be different.....it may be leaf springs. I think the fenders/ hood/ core support/ headlights wiring might be different also.
Other than that......all should be the same |
11-18-2006, 07:56 AM | #4 |
Re: GMC vs Chevy
The parking brake location on the 67 GMC is different than your 69 Chev. but that's not a problem if the GMC cab is in good shape.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
11-19-2006, 03:37 AM | #5 |
Re: GMC vs Chevy
Thanks guys. The deal might have fallen through. I will keep my eyes out though I really need a different truck.
11-19-2006, 03:40 AM | #6 |
Designated A-hole!
Re: GMC vs Chevy
Front clip is really the only major difference between chevy/gmc and the different yrs.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-19-2006, 08:02 AM | #7 |
blood type; Retumbo
Re: GMC vs Chevy
if a good Chevy support is not attainable you can just change the headlight buckets that are spot welded to the front.it may be a lot of work and end up with lights that dont fit correctly in the grill.
