Old 11-18-2006, 03:16 PM   #1
jamon8
jamon8's Avatar
new weatherstipping- doors wont close
I just hung my first door and it will not close all the way because of the weatherstripping that I put up
what do I do
jamon8 is offline   Reply With Quote
Old 11-18-2006, 06:55 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: new weatherstipping- doors wont close
ADJUST THE HINGES...
if you have the correct weatherstriping installed
rage'nrat638 is offline   Reply With Quote
Old 11-18-2006, 08:34 PM   #3
jamon8
jamon8's Avatar
its the correct weatherstripping and I have the hinges adjusted
Old 11-18-2006, 08:44 PM   #4
CPNEJR
CPNEJR's Avatar
if you loosen the bolts for the latch and move it out it will latch sooner allowing them to shut but make sure it isn't out too far or it wont be even and it will leak
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-18-2006, 10:44 PM   #5
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I feel your pain jamon8.
I replaced the old, squashed door seals on my truck with new ones and couldn't get the door to close unless I absolutely slammed them shut. It almost seems that some of the replacement door seals are too thick or the doors on our trucks have been adjusted to account for the old, thin seals and don't close properly with new ones.
A few people have already suggested adjusting the door hinges and latches. I would suggest that is a likely place to start. Funny how a simple thing like change the door seals turns into a major project.
I'm sorry I don't have a solution for you, I put the old ones back in because I am in the process of building a different cab to put on my chassis. I hope someone on the board has a solution for you.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-18-2006, 10:57 PM   #6
jamon8
jamon8's Avatar
In the bottom pic where the window frame meets the door skin. if you look at the weatherstrip, that sticks out into the jam, it is stopping the door from closing
I wish I knew how to circle things
I was considering cutting the weatherstrip down in that area
I know that when I put weatherstrips on my bird it was very hard to close the doors for a month
Old 11-19-2006, 05:12 AM   #7
roj2323
have you concidered warming up the rubber with a heat gun before closing it. it could just be that the rubber is stiff from being new and the heat would probably make it a little more maluble allowing the door to close. either way it will probably be a little while before they break in.
roj2323 is offline   Reply With Quote
Old 11-20-2006, 10:10 AM   #8
70c10
67-72 Addict!
70c10's Avatar
jamon8- did you leave an air gap (per the factory manual) to relieve pressure?. Another trick is to pierce holes every few inches around the perimeter. These won't be seen and they seem to help.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
